node-red-contrib-unifi 0.3.14
Node for Node-RED to connect to a UniFi Controller
node-red-contrib-unifi is a Node-RED module that allows to query/control UniFi devices via the official UniFi-Controller API. Based on npm package node-unifi
New functions
Version 0.3.14
- New command getDPIstats - Get array of DPI stats When updating from version 0.2.x to 0.3.x
- Beta release of new node (UnifiWS) that will use websocket for connection, listen to 'EVT_WU_Connected', 'EVT_WU_Disconnected', 'EVT_WU_Roam', 'EVT_WU_Roam_Radio', 'EVT_WG_Connected', 'EVT_WG_Disconnected', 'EVT_WG_Roam', 'EVT_WG_Roam_Radio', 'EVT_LU_Disconnected', 'EVT_LU_Connected'.
Supports the following Commands
- SitesStats : Site stats
- SiteSysinfo : Site sysinfo
- ClientDevices : Online client device(s)
- AllUsers : All client devices ever connected to the site
- UserGroups : User groups
- Health : Health metrics
- Dashboard : Dashboard metrics
- AccessDevices : Access points
- RogueAccessPoints : Rogue access points
- Events : Events
- Alarms : Alarms
- WlanSettings : Wlan Settings
- ListPortProfiles : List Port Profiles
Special Commands: (No GUI)
- disableWlan : Disable/Enable Wlan { command: "disableWlan", wlan_id: "use _id from command WlanSettings", disable: true }
- blockClient : Block Client { command: "blockClient", mac: "client MAC address" }
- unblockClient : Unblock Client { command: "unblockClient", mac: "client MAC address" }
- reconnectClient : Reconnect Client { command: "reconnectClient", mac: "client MAC address" }
- authorizeGuest : Authorize Client { command: "authorizeGuest", mac: "client MAC address", minutes: "minutes until authorization expires" }
- unauthorizeGuest : Unauthorize Client { command: "unauthorizeGuest", mac: "client MAC address" }
- restartAP : Reboot an Access point { command: "restartAP", mac: "device MAC address" }
- enableAP : Enable an Access point { command: "enableAP", device_id: "24 char device id" }
- disableAP : Disable an Access point { command: "disableAP", device_id: "24 char device id" }
- setAPLed : Set LED for Access point { command: "setapled", device_id: "24 char device id", mode: "off/on/default" }
- setSiteLed : Set LED for Site { command: "setsiteled", mode: true/false }
- site : Connect to site name { site: "site name"}
- getFirewallGroups: Get list of firewall groups { command: "getFirewallGroups" }
- addFirewallGroup: Add firewall group { command: "addFirewallGroup", group_name: "group-name", group_type: "address-group|ipv6-address-group|port-group", group_members: ["CIDRs", "IPs"] }
- editFirewallGroup: Edit firewall group { command: "editFirewallGroup", group_id: "group id", group_name: "group-name", group_type: "address-group|ipv6-address-group|port-group", group_members: ["CIDRs", "IPs"] }
- deleteFirewallGroup: Delete firewall group { command: "deleteFirewallGroup", group_id: "group id" }
- getFirewallRules: Get a list of firewall rules { command: "getFirewallRules" }
- getFirewallRule: Get a firewall rule { command: "getFirewallRule, rule_id: "id" }
- getFirewallRuleByName: Get a firewall rule by its name{ command: "getFirewallRuleByName, rule_name: "name" }
- enableFirewallRule: Enable a firewall rule { command: "enableFirewallRule", rule_id: "id" }
- disableFirewallRule: Disable a firewall rule { command: "disableFirewallRule", rule_id: "id" }
- getPoePortState: Get the PoE state of port x { command: "getPoePortState", device_id: "id", port: "port number" }
- enablePoePort: Enable POE on port x { command: "enablePoePort", device_id: "id", port: "port number", poe_mode: "off|auto|pasv24|passthrough" }
- disablePoePort: Disable POE on port x { command: "disablePoePort", device_id: "id", port: "port number" }
- forceProvision : Force provision { command: "forceProvision", mac: "device MAC address" }
- setPortProfiles: Set overrides for multiple ports of a device { command: "setPortProfiles", device_id: "24 char device id", port_overrides: [ {"port_idx": 1, "portconf_id": "id of the port profile", "name": "friendly name of the port", "poe_mode": "off|auto" }, ... ] }
- setLocate : Enable flash device LED (or other indication based on device) { command: "setLocate", mac: "device MAC address" }
- unsetLocate : Disable flash device LED (or other indication based on device) { command: "unsetLocate", mac: "device MAC address" }
- setOutletPortState : Set power outlet state for a specific port { command: "setOutletPortState", mac: "device MAC address", index: "port index", relay_state: "true|false", cycled_enabled: "true|false" }
- setWLanPassword : Change WLan password { command: "setWLanPassword", wlan_id: "SSID ID", x_passphrase: "New password" }
- getVouchers : Get available Vouchers from Guest Portal { command: "getVouchers" }
- createVouchers: Create new Vouchers for Guest Usage { command: "createVouchers", minutes: "expiration time in minutes", count: "number of vouchers", quota: "'0' is for multi-use, '1' is for single-use", note: "note added to voucher", up: "upload speed limit in kbps (remove if not used)", down: "download speed limit in kbps (remove if not used)", mbytes: "data transfer limit in MB (remove if not used)"}
- revokeVouchers: Revoke voucher { command: "revokeVouchers", voucher_id : "24 char _id of the voucher" }
- clientDevices: Returns a single client device { command: "clientDevices", mac: "device MAC address" }
- enableTrafficManagementRule: Enable a traffic management rule { command: "enableTrafficManagementRule", rule_id: "id" }
- disableTrafficManagementRule: Disable a traffic management rule { command: "disableTrafficManagementRule", rule_id: "id" }
- getTrafficManagementRule : Get traffic management rules, optional add rule_id { command: "getTrafficManagementRule", rule_id: "id" }
- enableTrafficRouteRule: Enable a traffic route rule { command: "enableTrafficRoutetRule", rule_id: "id" }
- disableTrafficRouteRule: Disable a traffic route rule { command: "disableTrafficRouteRule", rule_id: "id" }
- getTrafficRouteRule : Get traffic route rules, optional add rule_id { command: "getTrafficRouteRule", rule_id: "id" }
- getWLanSetting : Get WLan setting for selected WLan { command: "getWLanSetting", wlan_id: "id" }
- setWLanFilter : Set Device Access Filtering { command: "setWLanFilter", wlan_id: "id", policy: "allow|deny", mac: ['MAC Address'] }
- setDNSServer : Set DHCP DNS Server 1 and 2 { command: "setDNSServer", network_id: "id", dns1: "x.x.x.x", dns2: "x.x.x.x" }
- getNetworkConf : Get network configuration { command: "getNetworkConf" }
- setAPLedColor : Set LED color for Access point { command: "setapledcolor", device_id: "24 char device id", color: "Color Hex code" }
- getRadiusUsers : Get all radius users { command: "getRadiusUsers" }
- getRadiusProfiles : Get all radius profiles { command: "getRadiusProfiles" }
- createRadiusUser : Create radius user { command: "createRadiusUser", name: "account name", x_password: "password", tunnel_type: "optional 1-13", tunnel_medium_type: "optional 1-15", vlan: "optional vlan id" }
- updateRadiusUser : Update radius user { command: "updateRadiusUser", user_id: "24 char string _id of the user", name: "optional account name", x_password: "optional password", tunnel_type: "optional 1-13", tunnel_medium_type: "optional 1-15", vlan: "optional vlan id" }
- deleteRadiusUser : Delete radius user { command: "deleteRadiusUser", user_id: "24 char string _id of the user" }
- getDPIstats : Get array of DPI stats { command: "getDPIstats" }
Tips
- Use the command SiteStats to get your Unifi Site Name
- Use msg.payload = { site: "site name"}; to add the site name dynamically
- Use the command AccessDevices to get an Access Points Device ID
- Use the command ListPortProfile to get Profile ID
- Use the command GetWLanSettings to get SSID ID
- Use the command getNetworkConf to get network ID
- Use the command getRadiusUsers to get radious user ID
- See working examples in the examples folder
Requirements
- Installed UniFi-Controller version v4, v5, v6, v7 or v8
- Unifi controller user must have at least 'administrator' rights (not read-only)
Installation recommended
The recommended way to install this module is from the Node-RED GUI itself. Menu/manage palette/Install/search for unifi and then click install.
Installation manual
If Node-RED has been installed according to the instructions on https://nodered.org/docs/getting-started/installation, then the installation command for node-red-contrib-unifi has to be done from inside the Node-RED user-directory (default $HOME/.node-red) and prefixed with sudo.
- Thanks to all contributors.
- And a special thanks to Nokomis
MIT License
Copyright (c) 2023 Kristoffer Isaksson
