node-red-contrib-ui_j 1.2.19
UI nodes for node-red
cd ~\.node-red
npm install node-red-contrib-ui
Open your node-red instance and you should have UI nodes available at the bottom. The UI interface is available at http://localhost:1880/ui (if default node-red settings are used)
Discussions and suggestions
There is a google group: https://groups.google.com/forum/#!forum/node-red-contrib-ui
Developers
cd ~\.node-red\node-modules
git clone https://github.com/andrei-tatar/node-red-contrib-ui.git
cd node-red-contrib-ui
npm install
The plugin uses the dist
folder if it exists and contains an index.html
file. Make sure to delete it if you want to use the non-minified version.
After changing the front-end code in the src folder, gulp build
will update the minified files.
