node-red-contrib-typeform 0.1.1
A Node-RED Node for calling the typeform api
npm install node-red-contrib-typeform
Overview
This addon help you to retrieve the data from typeform, is composed by 2 nodes :
  • Typeform Answers
  • Typeform List
Typeform List
This node give you a list of the forms available on the account.
Typeform Answers
This node require the id of a form. You can pass in the input message the following optional parameters :
  • form : id of the form ( if is specified here overwrite the one in the configuration ).
  • since : the retrieved answers will be newer than this parameter.
  • until
  • offset
  • limit
Output
This node give the answers in the following structure :
    http_status
    stats
        responses
            showing
            total
            completed
    questions
            id
            question
    responses
            id
            metadata
                data_land
                date_submit
            hidden
                --- your hidden params ---
            answers
                --- your asnwers ( in raw format ) ---
            getAnswerByQuestion()
You can easily iterate over responses, for each response is available the function getAnswerByQuestion, you can obtain what the user reply to a question using
var choices = response.getAnswerByQuestion('How was your breakfast?');
The function outputs an array, this is in the case the question have multiple choices, or have an "other" choice ( in this case the first value of the array is an empty string and the second one is what the user write on "other" ).
Version: 0.1.1
Updated 8 years, 10 months ago
1 in the last week
  • typeformAPI
  • Typeform List
  • Typeform Answers
  • typeform
  • api
  • redconnect
  • Maurizio Carboni
