node-red-contrib-topic-timeframe-trigger 1.0.2
Node-RED node which observes input topics and only produces an output if n distinct topics are received n times each within the specified time frame.
Change directory to your node red installation:
$ npm install node-red-contrib-topic-timeframe-trigger
Outputs
When enough messages are received to trigger, a message is output as per the configuration. In addition, all of the messages received within the
timeframe are added to the message as an array property called triggers
Enabling extra debugging
Install node-red-contrib-config
and drag a config node into your workspace. Configure the node to set a global variable called topic-timeframe-trigger
with a JSON value of {"debug": true}
. Also make sure that the config tickbox for active
is unchecked. Redeploy. Now click the button on the config node.
This will trigger all instances of topic-timeframe-trigger
to write extra logging to the os syslog next time they're invoked.
