node-red-contrib-tinkerforge 0.0.27
Node-RED nodes to access Tinkerforge sensors
npm install node-red-contrib-tinkerforge
These nodes make use of Tinkerforge's javascript library to connect to a local brickd instance or to a remote instance (via Ethernet/WiFi brick)
From npm
or to from the git head stream
npm install tyrrellsystems/node-red-contrib-tinkerforge
Supported Bricklets
Currently there are nodes for the following bricklets
- Humidity Bricklet
- Humidity V2 Bricklet
- Moisture Bricklet
- Temperature Bricklet
- CO2 Bricklet
- Industrial Diginal In 4 Bricklet
- Industrial Diginal Out 4 Bricklet
- PTC Bricklet
- LED Strip Bricklet
- Motion Detector Bricklet
- Analog Out Bricklet 2.0
- Ambient Light Bricklet
- Remote Switch Bricklet
- Industrial Analog Out Bricklet
- Industrial Dual Analog In Bricklet
- Dual Relay Bricklet
- Temperature IR
- Tilt
- Distance US
- Distance IR
- Voltage/Current
- Hall Effect
- Sound Intensity
- Linear Poti
- Rotary Poti
- Line
- Barometer
- Piezo Speaker
- Laser Range Finder
- IO-4
- Distance IR V2.0
Adding more should be pretty trivial, these are just the bricks I currently access to for testing
Apache 2.0
Version: 0.0.27
Updated 4 years, 8 months ago
4 in the last week
TinkerForgeConfig
TinkerForge Motion
TinkerForge Humidity
TinkerForge HumidityV2
TinkerForge Moisture
TinkerForge PTC
TinkerForge Temperature
TinkerForge CO2
TinkerForge AmbientLight
TinkerForge Digital-In
TinkerForge IndDualAnalogIn
TinkerForge AnalogOut
TinkerForge IndAnalogOut
TinkerForge LEDStrip
TinkerForge Digital-Out
Tinkerforge RemoteSwitch
TinkerForge DualRelay
TinkerForge TemperatureIR
TinkerForge Tilt
TinkerForge DistanceUS
TinkerForge DistanceIR
TinkerForge VoltageCurrent
TinkerForge HallEffect
TinkerForge SoundIntensity
TinkerForge LinearPoti
TinkerForge RotaryPoti
TinkerForge Line
TinkerForge Barometer
TinkerForge PiezoSpeaker
TinkerForge LaserRange
TinkerForge IO-4
TinkerForge DistanceIRV2
- tinkerforge
- node-red
