node-red-contrib-thethingsio 0.0.2
Output node to send data to thethings.io
npm install node-red-contrib-thethingsio
Node-RED node to send data to thethings.io IoT platform
Install it
Local user installation:
cd ~\.node-red
Global installation (as root):
npm install -g node-red-contrib-thethingsio
Restart your node-red instance and you should have a "thethingsio" output node available.
Use it
This node sends the payload of the message (msg.payload) to your thethings.io account.
  • Token: Token which is used to authenticate to a thing.
  • Secure: Whether it should use a secure connection (HTTPS) or not.
  • Key: Name of the variable to send the data to.
  • Name: Name of the node.
You can override the token and key properties with the msg.token and msg.key message attributes. Likewise you can set a custom msg.timestamp to be used (format must be YYYYMMDDhhmmss).
Version: 0.0.2
Updated 11 months, 3 weeks ago
1 in the last day
4 in the last week
17 in the last month
  • thethingsio
  • thethings.io
  • iot
  • xoseperez
