node-red-contrib-td 0.0.9
A Node-RED node to write to TreasureData
npm install node-red-contrib-td
Japanese
A Node-RED node to write to TreasureData.
NPM
Pre-requisites
The node-red-contrib-td requires Node-RED to be installed.
Restart your Node-RED instance, the td node appears in the palette and ready for use.
Overview
Provides two nodes: a node that query tables, and a node that insert objects.
td in node
Use presto query to get data from Treasure Data.
Set presto query in msg.payload.
Tip: For information on how to write queries in Presto refer to this Presto Query Engine Introduction.
td out ndoe
Inserts objects into the specified table.
Set the objects to be inserted into msg.payload.
Tip: Set the data to be inserted in JSON format.
{"name":"test", "num":1234}
Acknowledgements
The node-red-contrib-td uses the following open source software:
  • td - Node.js Client Library for Treasure Data.
See license (Apache License Version 2.0).
Contributing
Both submitting issues to GitHub issues and Pull requests are welcome to contribute.
Developers
If the developer wants to modify the source of node-red-contrib-td, run the following code to create a clone.
cd ~\.node-red\node_modules
git clone https://github.com/joeartsea/node-red-contrib-td.git
cd node-red-contrib-td
npm install
Version: 0.0.9
Updated 4 years, 9 months ago
License: Apache
  • td
  • td in
  • td out
  • td
  • treasuredata
