node-red-contrib-syslog 1.1.0
A Node-RED syslog formatter
npm install node-red-contrib-syslog
This node will format msg.payload as a valid syslog message which can be sent to a syslog server via a UDP or TCP node.
msg.payload should be the message you want to send as a string. The message level, category, process, pid and hostname can be set within the node properties.
You can also set the properties dynamically by passing a msg.syslog object:
  • msg.syslog.level (0-7)
  • msg.syslog.category (0-23)
  • msg.syslog.process
  • msg.syslog.pid
  • msg.syslog.hostname
  • msg.syslog.time
This node will also parse incoming syslog formatted messages. It would typically come from an UDP input node set to output a Buffer. The msg.payload will contain the main message and the parsed properties will be available in the msg.syslog object.
Version: 1.1.0
Updated 7 years, 9 months ago
19 in the last week
  • syslog-node
  • syslog
