node-red-contrib-swagger 0.3.2
A Node-RED node able to invoke Web APIs generically based on a Swagger description
npm install node-red-contrib-swagger
Generic API Client for NodeRed
This is a node for NodeRed a tool for easily wiring together hardware devices, APIs and online services. This node provides a generic client for Web APIs by using Wordnik's Swagger javascript client. All that is required for you to automatically be able to invoke a given API is to have at your disposal the corresponding swagger description. Check out Swagger-Spec for additional information about the Swagger project, including additional libraries with support for other languages and more.
What's Swagger?
Taken from Swagger's own documentation:
"The goal of Swaggerâ„¢ is to define a standard, language-agnostic interface to REST APIs which allows both humans and computers to discover and understand the capabilities of the service without access to source code, documentation, or through network traffic inspection. When properly defined via Swagger, a consumer can understand and interact with the remote service with a minimal amount of implementation logic. Similar to what interfaces have done for lower-level programming, Swagger removes the guesswork in calling the service."
How to Install
Testing the Node
If you want to test your node you may go ahead and use existing swagger descriptions available online. For example you may want to use the prototypical example http://petstore.swagger.wordnik.com/api/api-docs.
Status
The node is maturing although some issues exist and a couple of features are in the to-do list.
Currently the node provides support for:
  • Parsing and invoking Swagger 1.0+ description
  • Content negotiation both for Request and Response content types
  • Authentication via Basic HTTP Auth and API Key
  • Invocation of APIs (except those with other non-supported authentication mechanisms).
Issues
Currently the node presents one issue due to an underlying library being used.
  • The parsing of Authentication details does not seem to be done correctly by the swagger-library and therefore authentication details specified at a resource level will not be adequately detected. We expect a solution will soon be implemented at the level of the Swagger javascript client which would resolve the problem altogether.
Future Features
We shall be providing the following functionality soon:
  • More detailed dynamic documentation of the API being used by the node so as to better help users in figuring out what the request message should look like.
  • Support for OAuth 2.0 authentication.
Copyright 2014 Knowledge Media Institute - The Open University.
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at apache.org/licenses/LICENSE-2.0
Version: 0.3.2
Updated 11 years, 1 month ago
License: Apache
Rating: 2.0 1
7 in the last week
  • swagger credentials
  • swagger api
  • swagger
  • web api
  • web service
  • client
