node-red-contrib-ssh-v2-reconnection 0.0.2
A Node-RED node for running remote ssh commands and supports reconnection attempts. Based on https://github.com/yroffin/node-red-contrib-ssh
npm install node-red-contrib-ssh-v2-reconnection
Available on NPM as https://www.npmjs.com/package/node-red-contrib-ssh-v2-reconnection
Based on https://github.com/yroffin/node-red-contrib-ssh which does not seem to be maintained.
Why?
I added this so I could turn on my linux HTPC via Alexa, triggering a WOL packet and then turn it off using SSH.
That's why SSH reconnection was important.
Changelog
  • fix unusable ssh key config
  • add reconnection attempts to the ssh client
Input: msg.payload has to contain the command.
Output: none
  • Ssh: ssh key path (optional but recommended)
  • Hostname: address of the target SSH server
  • Name: name of the node
  • Username: username of the target SSH server
  • Password: password of the target SSH server (set this if not using ssh key)
To-Do (help wanted)
  1. Add feature to reuse hosts/accounts instead of having to re-add every time
  2. Add output so that other nodes can consume the result
  3. Add option to consume more information(e.g. hostname) from other node
Version: 0.0.2
Updated 7 years, 6 months ago
Rating: 0.0
48 in the last week
  • ssh-client-v2
  • ssh
  • ssl
  • client
  • Yannick Roffin
