node-red-contrib-speaker 0.1.7
This node accepts PCM audio data and plays it to the speakers
npm install node-red-contrib-speaker
This node-red node accepts PCM audio data and plays it to the speakers.
It uses the node-speaker node
From your .node-red directory:
npm install --unsafe-perm node-red-contrib-speaker
Note : when installing on Raspberry PI, verify that the C compiler version is 4.8 (or more) before installing the package
The input should be a raw buffer containing the audio on msg.speech.
It can be used with the IBM Watson Text to Speech service on Bluemix.
You can define :
  • the number of audio channels (default: 2).
  • the sampling resolution (default: 16-bit).
  • the sampling rate (default: 11,025 Hz).
These default values are used by the IBM Watson Text to Speech service on Bluemix.
The audio parameters can be overwritten by msg.channels, msg.bitDepth and msg.sampleRate
Version: 0.1.7
Updated 7 years, 6 months ago
19 in the last week
  • speaker out
  • speaker
  • watson
  • text2speech
