node-red-contrib-sparkplug 2.1.1
A Sparkplug node for Node-RED
npm install node-red-contrib-sparkplug
A node for an MQTT Edge Node client for MQTT device communication using the Sparkplug Specification from Cirrus Link Solutions.
https://s3.amazonaws.com/ignition-modules/Current/Sparkplug+Specification.pdf
The client will connect to an MQTT Server and act as an MQTT Edge of Network (EoN) Node. It will publish birth certificates (NBIRTH), node data messages (NDATA), and process node command messages (NCMD) that have been sent from another MQTT client.
The client also provides and interface for other nodes to publish device birth certificates (DBIRTH), device data messages (DDATA), device death certificates (DDEATH), and receive device command messages (DCMD) that have been sent from another MQTT client.
Additional details on the example payloads below can be found here:
https://www.npmjs.com/package/sparkplug-client
Configuring the Sparkplug Node
When editing the Sparkplug Node the following properties are configurable:
  • ServerUrl: The URL of the MQTT server.
  • Port: The port of the MQTT server.
  • Username: The username for the MQTT server connection.
  • Password: The password for the MQTT server connection.
  • Client ID: A unique client ID for the MQTT server connection.
  • Group ID: An ID representing a logical grouping of MQTT EoN Nodes and Devices into the infrastructure.
  • Edge Node: An ID that uniquely identifies the MQTT EoN Node within the infrastructure.
  • Version: The Sparkplug version (currently: A or B).
  • Enable Cache: Whether to enable EoN node caching.
  • Publish Death: Whether to publish the edge node's death certicate when the client cleanly disconnects
Upon deploying the flow, the Sparkplug Node it will automatically connect to the MQTT Server. When the flow is stopped, the Sparkplug Node will cleanly close down the client connection by disconnecting from the MQTT Server.
Sparkplug Node Inputs
The Sparkplug Node expects input messages to be received on topics of the format: deviceId/type.
Acceptable values for each token in the topic are :
  • deviceId: A unique device ID string that does not contain the following reserved characters: '/', '#', "+".
  • type: DDATA | DBIRTH | DDEATH
The payload of each message will depend on the message type. The data types supported for metrics of payload differ based on the Sparkplug version. A full description of each versions format and data type support is beyond the scope of this readme and can be found in the Sparkplug specification linked above. The examples in this ready will use Sparkplug B.
DBIRTH message
Topic: deviceId/DBIRTH
Payload: An object with a "timestamp" (required), array of ALL "metric" objects (required).
Example:
    "timestamp" : 1465577611580
    "metrics" : [
            "name" : "my_int",
            "value" : 456,
            "type" : "int32"
            "name" : "my_float",
            "value" : 456,
            "type" : "float"
DDATA message
Topic: deviceId/DDATA
Payload: An object with a "timestamp" (required), array of one or more "metric" objects (required), and "position" (optional).
Example:
    "timestamp" : 1465577611580,
    "metrics" : [
            "name" : "my_int",
            "value" : 456,
            "type" : "int32"
DDEATH message
Topic: deviceId/DDEATH
Payload: An object with a "timestamp" (required).
Example:
For each metric included in the payloads, the following types are supported: int, long, float, double, boolean, string, bytes.
Sparkplug Node Outputs
The Sparkplug Node sends output messages in order to notify other nodes of a 'rebirth' request or to send a device command (DCMD) request.
'rebirth' message
Topic: rebirth
Payload: {}
The Sparkplug Node sends a 'rebirth' message in order to force all device nodes resend DBIRTH messages. This message is send once upon the deployment of the flow, after the Sparkplug Node has connected with the MQTT Server, and also every time the Sparkplug Node receives a node command (NCMD) message requesting a rebirth from itself all all devices.
command message
Topic: deviceId
Payload: An object with an array of one or more "metric" objects (required).
Example:
    "metrics" : [
            "name" : "my_int",
            "value" : 456,
            "type" : "int32"
            "value" : 456,
            "type" : "float"
A Sparkplug Node sends a command message every time it receives a device command (DCMD) message requesting write operations to the metrics of a specific device. The message will contain a single device ID in the topic and the payload will specify the metrics/values to write to the device. The device node specified by the device ID should process the command message and then send a DDATA message containing any metric values that have changed or been successfully written to.
Release History
  • 1.0.0 Initial release
  • 1.0.2 Bug Fixes
  • 1.1.0 Added connection status indicator, changed category
  • 1.2.0 Added 'Publish Death' config option, and mouseover config descriptions
  • 1.2.1 Added "node-red" keyword
  • 2.0.0 Added support for Sparkplug B and made version configurable
  • 2.1.0 Updated sparkplug-client version to 3.0.0
  • 2.1.1 Updated License and repo links
Copyright (c) 2016 Cirrus Link Solutions
All rights reserved. This program and the accompanying materials are made available under the terms of the Eclipse Public License v1.0 which accompanies this distribution, and is available at http://www.eclipse.org/legal/epl-v10.html
Contributors: Cirrus Link Solutions
Version: 2.1.1
Updated 5 years, 7 months ago
License: EPL-2.0
14 in the last week
  • sparkplug
  • tahu
  • mqtt
  • sparkplug
