node-red-contrib-sparkcore 0.0.12
Node-RED node to connect to Spark Core. This can be used to connect to Spark Core and call functions, read variables or listen to events
npm install node-red-contrib-sparkcore
Node-RED node to connect to Spark Core. This can be used to connect to Spark Core and call functions, read variables or listen to events.
Intsall
The node implements basic things to interact with Spark Core, such as call a function, read a variable and subscribe to events. This node defines INPUT and OUTPUT nodes. Input node can be used to call a function, read a variable and subscribe to events. The output node can be used to call a function and pass an input parameter. Following are the return values:
Function call
  1. msg.raw contains the raw JSON string returned
  2. msg.payload contains the return value of the function
  3. msg.id contains the core id
Read a Variable
  2. msg.payload contains the value of the variable
Subscribe to variables
  2. msg.payload the event data
  4. msg.published_at contain the published date and time
Version: 0.0.12
Updated 12 years, 5 months ago
12 in the last week
  • SparkCore in
  • SparkCore out
  • sparkcore
  • iot
