node-red-contrib-solaredge 0.1.0
Node-RED node to interface with SolarEdge solar photovoltaic inverters
npm install node-red-contrib-solaredge
This is a node for Node-RED to grab data from your SolarEdge inverter. You'll need an API key and your site ID. Talk to your solar PV installer if you need these.
This package adds 1 input node and 1 configuration node to Node-RED.
The configuration node defines the site and comprises the following options:
  • Site ID: The ID of your site.
  • API Key: The API key used to talk to the SolarEdge monitoring API. Must be a site API key, not an account users API key.
The input node comprises the following options:
  • Site: The SolarEdge site, defined above.
  • Command: The command to run against the SolarEdge monitoring API.
  • Interval: The interval, in seconds, between calls to the monitoring API.
Commands
The following commands are supported:
  • Details: This provides the overview of the system, including information such as the name, status, peak power, etc.
  • Overview: This provides data such as the lifetime energy output, current power output, etc.
For more information on the commands, see the SolarEdge monitoring API documentation.
MIT
Version: 0.1.0
Updated 8 years, 3 months ago
7 in the last week
  • solaredge-site
  • solaredge
  • solaredge
  • solar
  • photovoltaic
