node-red-contrib-solace 0.0.10
Publish/Subscribe using Solace Systems message routers and node-red
npm install node-red-contrib-solace
Node-Red (http://nodered.org) nodes for communicating with a Solace Systems message router (see http://www.solacesystems.com).
#Install
If you haven't already done so, install node-red
$ git clone [email protected]:node-red/node-red.git
Install the pre-requisite modules. From the top-level directory of Node-RED, run:
$ npm install
Then you can install the Solace node-red module
$ npm install node-red-contrib-solace
Edit your settings.js (also in the node-red top level directory) and add the following Solace configuration parameters anywhere after module.exports = {
// Retry time in milliseconds for Solace connections
solaceReconnectTries: 0,
solaceReconnectTime:  15000,
// Solace parameters
solaceLogLevel: 2,   //FATAL=0, ERROR=1, WARN=2, INFO=3, DEBUG=4, TRACE=5
generateSequenceNumber: false,
includeSenderId: false,
generateSendTimestamps: false,
generateReceiveTimestamps: false,
subscriberLocalPriority: 1,
subscriberNetworkPriority: 1,
noLocal: false,
Start node-red as normal
node red -v
Point your browser to http://localhost:1880
You should see orange solace input and output nodes in the pallet on the left side of the screen.
  • input
  • output
Drag either solace node to the canvas and double click to configure the topic, broker, and message type
Click on the pencil icon to the right of the broker selection box to configure a solace broker connection if one does not already exist.
Publish and subscribe just as you would with the mqtt node with some small differences namely:
  • the leading "/" of a topic name is implicit and not required
  • the solace wildcard characters are "*" and ">" rather than MQTT wildcards "+" and "#" (respectively)
  • the solace web streaming transport works over http(s)
A sample flow with wildcard subscriptions is provided in the flows subdirectory
#Usage
You will need access to a Solace Systems message router, which acts as a multi-protocol message broker.
#Test Sandbox
You can try it live on the Solace Systems public message router available at:
URL: http://69.20.234.126:8134
Username: demouser
Password: password
VPN: demo
Authors
Hans Jespersen - https://github.com/hjespers and Heinz Schaffner
#Feedback and Support
For more information, feedback, or community support email [email protected]
Version: 0.0.10
Updated 12 years, 5 months ago
7 in the last week
  • solace in
  • solace out
  • solace-broker
  • solace
  • pubsub
