node-red-contrib-snowboy 0.1.1
Node-RED node for Snowboy (bases on nodejs Snowboy : a customizable hotword detection engine for you to create your own hotword like "OK Google" or "Alexa").
npm install node-red-contrib-snowboy
Prerequisites
This node-red node is based on Snowboy nodejs, so first install it (Snowboy).
Run the following npm command in your Node-RED environment.
This package add 1 input node (Snowboy) to Node-RED.
The Snowboy node expect the following payload :
  • Readable stream: A stream object containing the audio to analyse. It may be a stream from microphone or audio file. Or
  • Buffer: A buffer containing the audio to analyse. It may be a stream from microphone or audio file.
N.B.: Each time an input payload is received (no matter stream or buffer), the previous stream (if any) is unpiped.
The snowboy node emit a message with the hotword detected as the payload. The stream (if any) is unpiped.
The Snowboy node comprises the following options:
  • Detector file: File name of the snowboy detector (like common.res)
  • Models: List of model
    • Hotwords: Hotwords to detect (like jarvis)
    • Sensitivity: Number between 0 and 1 indicate the level to detect hotwords. Default: 0.5
    • Model file: File name of the snowboy model (like jarvis.pmdl)
  • Multiple output:
    • False: One output for all the hotwords
    • True: One output for each hotword.
  • Debug: Set it to true if you want more log
Snowboy
Home Page
Full Documentation
The MIT License (MIT)
Version: 0.1.1
Updated 7 years, 2 months ago
7 in the last week
  • Snowboy
  • snowboy
  • hotword
  • jarvis
  • alexa
  • siri
  • speech to text
