node-red-contrib-smartfritz 0.2.0
Node-RED node for SmartHome with Fritz!Box and Dect!200 based on smartfritz library
Easily integrate AVM Fritz!Dect 200 switches into your node-RED flow. Based on the SmartFritz library. Please make sure to give some critical feedback. :)
Use npm install node-red-contrib-smartfritz
to install.
This package provides nodes to read and write signals to Fritz!Dect 200 switches via Node-RED. The configuration node lets you setup your Fritz!Box account and Actor Identification (AID).
The fritz read node is used to read the switch state (1/on, 0/off) from a Fritz!Dect 200 device. Make sure to use a valid AID or leave it empty. The message contains the info structure in msg.payload
The fritz write node is used to write the switch state (1/on, 0/off) from a Fritz!Dect 200 device. Make sure to use a valid AID or leave it empty. The message can contain boolean or string values in msg.payload
Contributing
- Fork it!
- Create your feature branch:
git checkout -b my-new-feature
- Commit your changes:
git commit -am 'Add some feature'
- Push to the branch:
git push origin my-new-feature
- Submit a pull request :D
History
Credits
Pedro Reboredo
MIT
