node-red-contrib-slackattach 0.1.2
A node-red module to post to Slack.com from Adrian Lansdown with Attachments for incoming message
npm install node-red-contrib-slackattach
A Node-RED node to post messages to Slack.
Slack Incoming Webhook
Slack output node.
Expects a msg.payload with a string that will be posted to the channel.
Webhook URL
This can be found on the Incoming WebHooks for the channel of your choice.
Username
This is the name that will appear above each post to the channel
Emoji Icon
This is the emoji that will be dispalyed next to each of the messages in the channel. All possible Emoji icons can be found at Emoji Cheat Sheet
Destination channel
You can optionally override the destination channel if required - either in the edit dialogue or by setting msg.channel.
You can also create Slack attachments by adding a msg.attachments property that must be an array.
For more information see Slack Incoming Webhooks.
Slack Outgoing Webhook
Work in progress
Slack Bot In
Slack bots input node.
Will listen for messages in any channels, Groups or DM the bot is invited to.
Outputs the msg.payload as the incoming message.
Outputs msg.SlackObj with full Slack message details
Bot API Token
This can be found on the Bots intregration.
Channel
You can optionally limit the channel for this node to emit messages from. By default it will send all messages recieved.
Slack Bot Out
Slack bots output node.
Expects a msg.payload with a string that will be posted to Slack based on the Bot API token provided.
Bot API Token
Destination Channel
You can optionally override the destination channel if required - either in the edit dialogue or by setting msg.channel. The bot must be a member of that channel to post.
Version: 0.1.2
Updated 3 months, 3 weeks ago
3 in the last day
18 in the last week
47 in the last month
  • slack
  • Slack Bot In
  • Slack Bot Out
  • slack
  • post
  • attachments
  • berni78
