node-red-contrib-sequencer 1.0.0
A record and replay node for node red message sequences.
Description
These nodes allow you to record and replay msg-object sequences within node red. The time between each message is measured, so the replay has the same delays as the original sequence.
Install via NPM
From inside your node-red directory:
npm install node-red-contrib-sequencer
What's inside?
It includes two nodes:
recorder
: lets you record sequences of objects, which can be replayed by the player node.player
: the output node lets you replay previously or even manually generated sequences. The player can replay multiple sequences in parallel.
The recorder produces sequences in the following format, which can be read by the player:
"name": "DemoSequence",
"seq": [
"data": {
"topic": "MyTopic",
"payload": "A"
"delay": 0
"data": {
"topic": "MyTopic",
"payload": "B"
"delay": 1250
"data": {
"topic": "MyTopic",
"payload": "C"
"delay": 795
name
you already guessed it, the name of the sequence to call it to play, pause or stop inplayer
seq
the actual sequence, which contains an array of element objects.data
this object will be put into a new msg when being replayed.delay
the time in milliseconds, the player waits before thedata
content is being sent.
To get started, use these commands, to use the nodes.
Recorder
Following commands are available:
msg.start
records a new sequencemsg.stop
stops current recording and return already recorded sequence
When recording stops, the recorded sequence will be emitted as a single message.
Player
A player node can run multiple sequences in parallel. These are identified by the sequence name. Following commands are available:
msg.name
The name of the sequence being played, paused, stopped or loaded. Sequence objects already contain a name, which can be overwritten with this.msg.sequence
load sequences into player (format: JSON or sequence object)msg.play
plays the loaded sequence(s). Property value = sequence name(s)msg.pause
pauses the currently played sequence / proceed with msg.playmsg.stop
stops the currently played sequence(s) / start over with msg.playmsg.remove
removes a sequence from the playermsg.enumerate
emits an array containing all names of currently loaded sequences
play, pause, stop and remove properties take either a string or an array containing the name(s). If the value is an empty string it is assumed, that all loaded sequences shall be played / paused / stopped or removed.
Example
[{"id":"a923577c.465c58","type":"player","z":"e6a28ad.47ae678","name":"Player node","runOnLoad":false,"x":770,"y":300,"wires":[["ff999048.73bd2"]]},{"id":"c899145c.082fa8","type":"inject","z":"e6a28ad.47ae678","name":"","topic":"","payload":"do","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":740,"wires":[["6764ddd5.8515c4"]]},{"id":"96eda8e.4179f58","type":"inject","z":"e6a28ad.47ae678","name":"Stop","topic":"","payload":"MySequence1","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":220,"wires":[["cc106124.dc5e7"]]},{"id":"2fe32836.cdda58","type":"inject","z":"e6a28ad.47ae678","name":"Play","topic":"","payload":"MySequence1","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":140,"wires":[["62e2f3ee.98923c"]]},{"id":"7ce616bc.34b688","type":"inject","z":"e6a28ad.47ae678","name":"Pause","topic":"","payload":"MySequence1","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":180,"wires":[["7a42c6da.fe0168"]]},{"id":"31b64ef5.573502","type":"inject","z":"e6a28ad.47ae678","name":"Load","topic":"","payload":"{\"name\":\"MySequence1\",\"seq\":[{\"data\":{\"topic\":\"Task one\",\"payload\":50},\"delay\":0},{\"data\":{\"payload\":10,\"anyProperty\":\"can be put in here\"},\"delay\":2800},{\"data\":{\"topic\":\"Task III\",\"payload\":\"on\"},\"delay\":4300},{\"data\":{\"topic\":\"my value\",\"payload\":0},\"delay\":2100}]}","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":100,"wires":[["bee47b4a.b9b798"]]},{"id":"62e2f3ee.98923c","type":"change","z":"e6a28ad.47ae678","name":"payload -> play","rules":[{"t":"move","p":"payload","pt":"msg","to":"play","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":240,"wires":[["a923577c.465c58"]]},{"id":"ff999048.73bd2","type":"debug","z":"e6a28ad.47ae678","name":"","active":true,"console":"false","complete":"true","x":950,"y":300,"wires":[]},{"id":"bee47b4a.b9b798","type":"change","z":"e6a28ad.47ae678","name":"payload -> sequence","rules":[{"t":"move","p":"payload","pt":"msg","to":"sequence","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":200,"wires":[["a923577c.465c58"]]},{"id":"2b83123d.5dda3e","type":"inject","z":"e6a28ad.47ae678","name":"Start","topic":"","payload":"MyRecord1","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":620,"wires":[["f2a1bace.d82888"]]},{"id":"e674a51e.742528","type":"inject","z":"e6a28ad.47ae678","name":"Stop","topic":"","payload":"MyRecord1","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":660,"wires":[["a6b8a9a4.b16798"]]},{"id":"5b6f5bc0.bf9e14","type":"debug","z":"e6a28ad.47ae678","name":"","active":true,"console":"false","complete":"true","x":890,"y":640,"wires":[]},{"id":"a6b8a9a4.b16798","type":"change","z":"e6a28ad.47ae678","name":"payload -> stop","rules":[{"t":"move","p":"payload","pt":"msg","to":"stop","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":660,"wires":[["d21b1841.9d7af8"]]},{"id":"d21b1841.9d7af8","type":"recorder","z":"e6a28ad.47ae678","name":"Recorder node","maxElements":"4","maxDuration":"10","startImmediately":false,"x":720,"y":640,"wires":[["5b6f5bc0.bf9e14","a923577c.465c58"]]},{"id":"c1078529.ee7028","type":"inject","z":"e6a28ad.47ae678","name":"","topic":"","payload":"re","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":780,"wires":[["6764ddd5.8515c4"]]},{"id":"4b76cb4f.7174b4","type":"inject","z":"e6a28ad.47ae678","name":"","topic":"","payload":"mi","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":820,"wires":[["6764ddd5.8515c4"]]},{"id":"cecc77a3.479d78","type":"inject","z":"e6a28ad.47ae678","name":"","topic":"","payload":"fa","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":860,"wires":[["6764ddd5.8515c4"]]},{"id":"dbdd609a.7d29b","type":"inject","z":"e6a28ad.47ae678","name":"","topic":"","payload":"so","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":900,"wires":[["6764ddd5.8515c4"]]},{"id":"f7f547d5.9fbbd8","type":"inject","z":"e6a28ad.47ae678","name":"","topic":"","payload":"la","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":940,"wires":[["6764ddd5.8515c4"]]},{"id":"cb86991c.62ece8","type":"inject","z":"e6a28ad.47ae678","name":"","topic":"","payload":"ti","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":980,"wires":[["6764ddd5.8515c4"]]},{"id":"e78e353c.83bb98","type":"inject","z":"e6a28ad.47ae678","name":"Enumerate","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":460,"y":120,"wires":[["d32130f4.391c7"]]},{"id":"3b2a2ce0.c4d5d4","type":"inject","z":"e6a28ad.47ae678","name":"Stop","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":460,"wires":[["cc106124.dc5e7"]]},{"id":"12444aa9.edbbb5","type":"inject","z":"e6a28ad.47ae678","name":"Play","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":380,"wires":[["62e2f3ee.98923c"]]},{"id":"42516c6c.bdae94","type":"inject","z":"e6a28ad.47ae678","name":"Pause","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":130,"y":420,"wires":[["7a42c6da.fe0168"]]},{"id":"a66608e5.5999f8","type":"inject","z":"e6a28ad.47ae678","name":"Load","topic":"","payload":"{\"name\":\"MySequence2\",\"seq\":[{\"data\":{\"topic\":\"\",\"payload\":\"mi\"},\"delay\":0},{\"data\":{\"topic\":\"\",\"payload\":\"fa\"},\"delay\":1250},{\"data\":{\"topic\":\"\",\"payload\":\"so\"},\"delay\":795},{\"data\":{\"topic\":\"\",\"payload\":\"so\"},\"delay\":998},{\"data\":{\"topic\":\"\",\"payload\":\"re\"},\"delay\":2733},{\"data\":{\"topic\":\"\",\"payload\":\"do\"},\"delay\":713},{\"data\":{\"topic\":\"\",\"payload\":\"re\"},\"delay\":1497}]}","payloadType":"json","repeat":"","crontab":"","once":false,"x":130,"y":300,"wires":[["bee47b4a.b9b798"]]},{"id":"7a42c6da.fe0168","type":"change","z":"e6a28ad.47ae678","name":"payload -> pause","rules":[{"t":"move","p":"payload","pt":"msg","to":"pause","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":280,"wires":[["a923577c.465c58"]]},{"id":"cc106124.dc5e7","type":"change","z":"e6a28ad.47ae678","name":"payload -> stop","rules":[{"t":"move","p":"payload","pt":"msg","to":"stop","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":320,"wires":[["a923577c.465c58"]]},{"id":"d32130f4.391c7","type":"change","z":"e6a28ad.47ae678","name":"payload -> enumerate","rules":[{"t":"move","p":"payload","pt":"msg","to":"enumerate","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":120,"wires":[["a923577c.465c58"]]},{"id":"f0833b23.bd3208","type":"comment","z":"e6a28ad.47ae678","name":"Trigger all sequences","info":"","x":120,"y":340,"wires":[]},{"id":"a64f002f.736e9","type":"comment","z":"e6a28ad.47ae678","name":"Load MySequence2","info":"","x":110,"y":260,"wires":[]},{"id":"6764ddd5.8515c4","type":"change","z":"e6a28ad.47ae678","name":"Filter unwanted properties","rules":[{"t":"delete","p":"topic","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":740,"wires":[["d21b1841.9d7af8"]]},{"id":"f2a1bace.d82888","type":"change","z":"e6a28ad.47ae678","name":"payload -> start","rules":[{"t":"move","p":"payload","pt":"msg","to":"start","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":620,"wires":[["d21b1841.9d7af8"]]},{"id":"54598abc.0b16c4","type":"comment","z":"e6a28ad.47ae678","name":"Play the keys","info":"","x":90,"y":700,"wires":[]},{"id":"7c35f81e.19cb68","type":"comment","z":"e6a28ad.47ae678","name":"Start / Stop recording","info":"","x":120,"y":560,"wires":[]},{"id":"1876f2c7.f5ef4d","type":"comment","z":"e6a28ad.47ae678","name":"Load newly recorded sequence","info":"","x":870,"y":480,"wires":[]},{"id":"c6eddba9.47dcb8","type":"comment","z":"e6a28ad.47ae678","name":"Load and trigger MySequence1","info":"","x":150,"y":60,"wires":[]},{"id":"8a37bd87.8dac4","type":"inject","z":"e6a28ad.47ae678","name":"Remove","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":140,"y":500,"wires":[["adfd9183.f2b96"]]},{"id":"adfd9183.f2b96","type":"change","z":"e6a28ad.47ae678","name":"payload -> remove","rules":[{"t":"move","p":"payload","pt":"msg","to":"remove","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":360,"wires":[["a923577c.465c58"]]}]
