node-red-contrib-salesforce 0.8.1
A set of Node-RED nodes to interact with Salesforce and Force.com.
npm install -s node-red-contrib-salesforce
Each node uses a connection object to hold and share Salesforce connected app settings (consumer key, consumer secret, username, etc.). This determines the org that each node operates against. Credential information can alternatively been supplied by environment variables (Heroku, Bluemix, Azure friendly) or in the msg object.
SOQL
Executes a SOQL query
select id, name
from contact
limit 2
If "Return JSON only" is selected, message.payload contains an array of result objects. Otherwise the resulting message has the following properties:
- msg.payload.size - the number of records returned from the query
- msg.payload.records - the array of javascript nForce objects returned from the query. The nforce objects are useful for doing updates etc., as they have dirty checking and are already structured for an DML update, but do not match what Node-Red debug window shows.
The query can be configured in the node, however if left blank, the query should be set in an incoming message on msg.query
. See the Salesforce SOQL documentation for more information.
SOSL
Executes a SOSL query
FIND {united*} IN ALL FIELDS
RETURNING Account (Id, Name), Contact (Id, Name)
The resulting message has the following properties:
- msg.payload.size - the number of records returned from the query.
- msg.payload.records - the array of records returned from the query.
. See the Salesforce SOSL documentationor more information.
DML
Executes an insert, update, upsert or delete DML statement.
The action and object can be configured in the node, however if left blank, the following should be set in an incoming message:
msg.action
- the DML action to performmsg.object
- the sObject for the DML action
Insert Action
This action inserts the contents of msg.payload
and returns the newly created ID.
"firstname": "Nikola",
"lastname": "Tesla"
Update Action
This action updates the specified record with the the contents of msg.payload
. It assumes that the payload contains an id
property with the id of the record to be updated.
"id": "00337000002uFbW",
"lastname": "Tesla"
Upsert Action
The upsert action matches contents of the msg.payload
with existing records by comparing values of one field. If you don’t specify a field when calling this action, the operation uses the id value in the msg.payload
to match with existing records to update. Alternatively, you can specify a field to use for matching in msg.externalId
. This field must be marked as external ID. If a matching record is not found, a new records is inserted.
Sample msg.payload
to be used with an external id.
"lastname": "Tesla"
Sample msg.externalId
specifying the field and value to be used for matching.
"field": "Ext_ID_c",
"value": "12345"
If record(s) are updated, the resulting payload will resemble:
"payload": {
"success": true,
"object": "contact",
"id": {
"field": "Ext_ID__c",
"value": "12345"
"action": "update"
If a new record is inserted, the resulting payload will resemble the following containing the id of the newly created record:
"payload": {
"success": true,
"id": "00337000002uwUVAAY",
"action": "insert"
Delete Action
This action deletes the record specified by the id property in msg.payload
See the Apex DML Operations for more information.
Streaming
Creates a client that subscribes to topics for the Streaming API.
Subscription starts once a msg is received as input. The msg object payload gets ignored, but the following properties are used when present:
action
:subscribe
orunsubscribe
When no action is configured it defaults to subscribe. An unknown value for action is interpreted as unsubscribetopic
: the subscription topic to listen to, defaults to the one from configuration. Topic needs to be complete and start with/
. See inline help for optionssf
: object with Salesforce credentials:username
,password
,clientSecret
,clientToken
. Can have just one of these. Uses configuration values as default
Supported events to subscribe
- Platform events:
/event/[NameOfPlatformEvent]
-> Listen to the Platform event API - Push Topic:
/topic/[NameOfPushTopic]
-> Listen to changes in sObjects - Streaming (Generic):
/u/notifications/[SomeChannelName]
-> Listen to generic Push Topics (deprecated) - Change Data Capture:
- All configured changes:
/data/ChangeEvents
- Opportunity:
/data/OpportunityChangeEvent
(Same for other Standard objects) - Custom object:
Custom__ChangeEvent
(replacing__c
with__ChangeEvent
Check the Developer guide for more details.
When the client receives a message it sends msg.payload
with the following:
msg.payload.event
- the information on the event that was received.msg.payload.sobject
- the sobject information received.
Assuming a PushTopic was created with the query SELECT Id, Name FROM Contact
, then a resulting message would look like:
"event": {
"type": "updated",
"createdDate": "2015-07-31T18:38:21.000+0000"
"sobject": {
"Name": "Nikola Tesla",
"Id": "a0037000001pplrZZZ"
See the Quick Start Using Workbench to get started or the Streaming API documentation for complete details.
Outbound Messages (OBM)
When used with an http in node, parses the XML from a Salesforce Outbound Message to a JSON object.
The resulting msg.payload
should look something like:
"organizationId": "00D37000000PdLZAE1",
"actionId": "04k370000008OrqZZE",
"sobject": {
"type": "Contact",
"id": "a0037000001I1EvWWO",
"name": "Nikola Tesla",
"lastname": "Tesla"
"sessionId": "00D37000000PdLB!"
Connect this node downstream from a POST http input node to parse the XML received from an Outbound Message call from Salesforce. Use the URL from the http in node for the Endpoint URL for your Outbound Message. See the Salesforce Setting Up Outbound Messaging documentation for more information.
Chatter
Posting chatter messages to users or objects. The msg payload turns into the body of the chatter message. Currently only plain text is supported.
"payload": "Hello World",
"title": "Message title",
"ParentId": "ID of object",
"RelatedRecordId": "RelatedRecord"
When ParentId
is not supplied, the user specified in the configuration is used. RelatedRecordId
is optional.
Return value is similar (for now) to object insert
