node-red-contrib-repeat 0.0.27
Limit the number of times a message is allowed to pass through the node before it is discarded
npm install node-red-contrib-repeat
Repeat NodeRED Node
NPM
Allow a message to pass through this node for an specific number of times, after which it will be discarded. This unveils the ability to limit the loops over a flow to N times.
Optionally a second output can be enabled to grasp the message once the repetitions are exhausted.
Note: See info panel in NodeRED for up-to-date usage details.
Screenshot
rpm install -g node-red-contrib-repeat
Notes on the design
This node is designed in a stateless fashion; no state is stored in the node's context, and instead each message stores its state for the current repeat node (in the _loopController property). This has some drawbacks, like the fact that currently it does not support more than 1 repeat node operating upon a msg simultaneously. However, the drawbacks of this approach are outweighed by the advantatges and safety of not having to manage a node-centralized state.
Version: 0.0.27
Updated 10 years, 9 months ago
116 in the last week
  • repeat
  • loop
  • repeat
  • repetitions
  • iterator
