node-red-contrib-raspihats 2.0.0
Node Red nodes for controlling raspihats.com boards
A collection of Node-RED nodes for the Raspberry Pi add-on boards from raspihats.com. See below for a list.
Go to your Node-RED user data directory and install this package:
cd $HOME/.node-red
npm install node-red-contrib-raspihats
If Node-RED is running, then you'll then need to restart Node-RED for it to pick-up the new nodes.
Nodes Categories Information
1. Raspihats I2CHat
DI Read(DigitalInput)
Node used to read a I2C-HAT Digital Input channel state, generates a msg
object with msg.payload
that is true
or false
depending on the state of the Digital Input channel.
A polling mechanism is used for reading the DigitalInputs states, target polling interval is 10ms.
DQ Read (DigitalOutput)
Node used to read a I2C-HAT Digital Output channel state, generates a msg
that is true
or false
A polling mechanism is used for reading the DigitalOutputs states, target polling interval is 10ms.
DQ Write(DigitalOutput)
Node used to write a I2C-HAT Digital Output channel state, expects a msg
object with a msg.payload
that is true
or false
and writes this to the Digital Output channel.
TODO
- Replace polling mechanism for Raspihats I2CHat/DI Read with a interrupt based mechanism
Copyright and license
Copyright 2016, 2016 Florin C. under the MIT license.
