node-red-contrib-ramp-thermostat 0.8.3
A Node-RED node that emulates a programmable thermostat.
npm install node-red-contrib-ramp-thermostat
ramp-thermostat
NPM version
A Node-RED contrib-node that emulates a programmable thermostat.
Wikipedia Source: A programmable thermostat is a thermostat which is designed to adjust the temperature according to a series of programmed settings that take effect at different times of the day. Programmable thermostats may also be called clock thermostats.
The ramp-thermostat controls an actuator depending on the current input temperature and the target temperature (setpoint). The target temperature is defined by a profile for a day period (00:00-23:59). A weekly or holiday setting can be achieved using several profiles.
The target temperature is defined by a profile that provides the value depending on the current time 00:00-23:59. The profile consists of several points whose connections build a sequence of lines. The switching moment can be optimized by defining a gradient line like a ramp.
A profile has at least 2 points and must start at 00:00 and end at 23:59.
The hysteresis is used to prevent osciliation. The [+] value is added to the target and the [-] (absolute) value is subtracted from the target. Within this neutral zone no action accurs.
This node expects a numeric msg.payload containing the current temperature (number). The msg.topic should be set to setCurrent. It will calculate the target temperature depending on msg.payload at the current time and output 3 values:
  • state (boolean)
  • current temperature (number)
  • target temperature (number)
The state (true/false) is used to control an actuator. The current and target temperature outputs can be wired e.g. into an ui_chart node.
Runtime settings
setTarget
msg.topic: setTarget
msg.payload: nn.n (number)
The target will be valid until a new target or a profile is set again or until node-red is restarted.
setHysteresisPlus
msg.topic: setHysteresisPlus
The Hydteresis will be valid until a new hysteresis is set again or until node-red is restated.
setHysteresisMinus
msg.topic: setHysteresisMinus
getProfile
msg.topic: getProfile
msg.payload: profile-name
The profile object is sent to the output 3:
msg.payload: {
  "name": "profile-name",
  "points": [{
    "00:00": 18
    "04:00": 18
    "08:00": 20.5
    "12:00": 20.5
    "12:00": 19
    "12:30": 19
    "13:30": 20.5
    "19:00": 20.5
    "19:00": 18
    "23:59": 18
setProfile
msg.topic: setProfile
The profile-name is one of the existing profiles that are configured in the ramp-thermostat node.
You can even define an input profile (JSON object) with more than 10 points:
msg.payload: {
    "name": "dining room",
    "points": [
        {"00:00": 18},
        {"03:00": 18},
        {"06:00": 18.5},
        {"08:00": 20},
        {"10:00": 20},
        {"11:00": 20.5},
        {"12:30": 20.5},
        {"12:30": 19.5},
        {"15:00": 19.5},
        {"17:00": 20.5},
        {"19:00": 20.5},
        {"19:00": 20},
        {"21:30": 20},
        {"21:30": 18},
        {"23:59": 18}
Examples
rt-office3
The profile is defined using 6 points:
"time" : temp
"00:00": 18.0
"03:00": 18.0
"06:00": 20.0
"19:00": 20.0
"20:00": 18.0
"23:59": 18.0
Version: 0.8.3
Updated 6 years, 9 months ago
Rating: 3.0 4
73 in the last week
  • ramp-thermostat
  • profile
  • thermostat
  • profile
  • heating control
  • tmeperature control
  • energy saving
  • multtple heating zones
  • single room temperature control
