node-red-contrib-push 0.0.1
Push notifications for node-red
is a Node-RED package that allows you to send APN, GCM and Web push notifications.
It uses the node-apn library for APN notifications, node-gcm for GCM notifications and web-push for Web notifications.
Table of Contents
APN
You can use the apn
node to send notifications to iOS and Safari devices. You will need to configure a Provider Authentication Token and then create an app
configuration, which will contain the token, as well as the topic (bundle-id) of your app and wheather it's using a production or sandbox environment. Assign the app
configuration to the apn
node and you are ready to send notifications.
You can use the apn-notification
node to set the properties of a notification, or you can send the values in the msg.notification
object. You can also set the raw payload which will be sent to Apple in the msg.rawNotification
object. More information available in the apn
node info tab.
The tokens must be provided in the msg.tokens
object as an array.
GCM
The gcm
node is used to send notifications to Android and iOS (if it's configured in Firebase) devices. For Chrome notifications, check out the web
node. You will need to configure your GCM Api Key and assign it to the node.
You can use the gcm-notification
object.
The recipient of the notification can be specified by setting one of the following keys: to
, topic
, condition
, registrationTokens
or tokens
More information available in the gcm
node info tab.
Web
The web
node is used to send notifications to Chrome, Firefox, Opera, and Samsung Internet browsers. For a list of supported versions of those browsers, check the web-push page.
Some browsers (Chrome and Opera) requires a GCM Api Key to send notifications, so you will need to configure it in the node.
You can use the web-notification
object.
The device tokens must be provided in the msg.tokens
object and they must contain the endpoint
, as well as the p256dh
and the auth
keys.
More information available in the web
node info tab.
Additional information
The apn
, gcm
and web
nodes will return the result in the msg.result
key.
Example flow
You can find an example flow in exampleFlow.json
Screenshots
Copyright 2017 Mihail Cristian Dumitru
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at
