node-red-contrib-prolights 0.0.1
Node-RED node that compose input for Artnet node to control Prolights lamps
npm install node-red-contrib-prolights
Go to Gunnebo
Node-RED node that composes input for node-red-contrib-artnet to control Prolights lights.
Gunnebo (OMX: GUNN) is a multinational corporation headquartered in Gothenburg, Sweden, specializing in security products, services and solutions mainly in the areas of cash management, entrance security, electronic security and safes & vaults. The Gunnebo Group has operations in 32 countries with approximately 5,500 employees (Jan 2016) and a reported global revenue of �660 million for 2015. Gunnebo has been listed on the Stockholm Stock Exchange in Sweden since 1994 and can be found on the NASDAQ OMX Nordic Exchange Stockholm in the Mid Cap Industrials segment.
Run the following command in the root directory of your Node-RED install. Usually this is ~/.node-red
Using
You can either setup node via editor or with a payload like the following example:
msg.payload = {
  device_type: "PIXIEWASH",
  channels: "13channels",
  address_start: 1,
  pan: 100,
  tilt:140,
  dimmer:20,
  shutter:3,
  red:10,
  green:10,
  zoom:255
You can also fade to values, either for a single channel or multiple channels. You must specify the 'transition' and also a 'duration' in milliseconds:
msg.payload = {
  address_start: 1,
  transition: true,
  duration: 4000,
  red:10,
  zoom:255
While configuring node via editor you can specify "-1" as a value for any channel. In that case channel value doesn't change.
Version: 0.0.1
Updated 7 years, 9 months ago
1 in the last week
  • prolights out
  • prolights
  • artnet
  • dmx
  • light
