node-red-contrib-primitives 0.2.0
Simple node-red nodes for manipulating primitive values.
Simple node-red nodes for working with primitive values
npm install node-red-contrib-primitives
Arrays
Nodes for working with arrays
array-iterate
Allows looping over an array.
array-join
Joins an array on the supplied character
Booleans
Nodes for working with boolean values
bool-toggle
Toggles a boolean value
Numbers
Nodes for working with Numbers
number-inc
Increments the value of a property
number-dec
Decrements the value of a property
Strings
Nodes for working with Strings
string-split
Splits the string value of a property on the configured character.
