node-red-contrib-postgres-listen 0.1.0
A Node-RED node to listen to pg_notify
npm install node-red-contrib-postgres-listen
Overview
This add-on, allows to listen to PostgreSQL pg_notify mechanism.
The node takes two parameters :
  • postgresdb : The PostgreSQL connection configuration
  • channel : The channel name specified in the pg_notify command
PostgreSQL sample code
  1. Create a base table:
     CREATE TABLE realtime
         id INTEGER DEFAULT nextval('realtime_id_seq'::regclass) NOT NULL,
         title CHARACTER VARYING(128),
         PRIMARY KEY (id)
  2. Create a trigger on the table:
     CREATE TRIGGER "updated_realtime_trigger"
       BEFORE INSERT OR DELETE OR UPDATE ON realtime
       FOR EACH ROW
     EXECUTE PROCEDURE notify_realtime()
  3. Create a trigger function:
     CREATE FUNCTION public.notify_realtime()
         RETURNS trigger
         LANGUAGE 'plpgsql'
         COST 100.0
         VOLATILE NOT LEAKPROOF
     AS $BODY$
     BEGIN
         PERFORM pg_notify('addedrecord', '' || row_to_json(NEW));
         RETURN NEW;
     END;
     $BODY$;
Result
The node will produce a message like that :
{"name":"notification","length":47,"processId":16147,"channel":"addedrecord","payload":{"id":2,"title":"plopcsd"}}
All fields are generated by Postgres with payload being the content of the table row.
Version: 0.1.0
Updated 1 month, 2 weeks ago
0 in the last day
4 in the last week
22 in the last month
  • postgresdb
  • PG Listen
  • postgres
  • postgresql
  • pg_notify
  • arkancrow
