node-red-contrib-postgres 0.5.1
A Node-RED node to query PostgreSql
npm install node-red-contrib-postgres
A Node-RED node to query PostgreSQL.
The node-red postgres node uses a template node to set the query and uses msg.queryParameters as params for the query.
Each property in msg.queryParameters can be used as $propertyName in the query, see the 'setup params' and 'format query' node in the example.
The msg it then passed to the postgres node.
If you want the output of the query, check the 'Receive output' box in the postgres node.
The result of the query is then set on the msg.payload property which can be sent to a http node.
Example DB
CREATE TABLE public.table1
    field1 character varying,
    field2 integer
WITH (
    OIDS=FALSE
ALTER TABLE public.table1
  OWNER TO postgres;
INSERT INTO public.table1(
            field1, field2)
    VALUES ('row1',1);
            field1, field2)
    VALUES ('row2',2);
Example node-red flow
Import the flow below in an empty sheet in nodered
[{"id":"168f2030.e970e","type":"postgresdb","z":"d1b19967.2e4e68","hostname":"localhost","port":"5432","db":"postgres"},{"id":"37e19274.c81e6e","type":"inject","z":"d1b19967.2e4e68","name":"trigger","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"00 12 * * *","once":false,"x":135,"y":78,"wires":[["ec61e7da.139e18"]]},{"id":"3bffa50b.c4005a","type":"template","z":"d1b19967.2e4e68","name":"format query","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"select * from table1 where field2 > $param1","x":528,"y":76,"wires":[["e3ff7e9.f1c008"]]},{"id":"e3ff7e9.f1c008","type":"postgres","z":"d1b19967.2e4e68","postgresdb":"168f2030.e970e","name":"","output":true,"outputs":1,"x":695,"y":72,"wires":[["9e662745.6199d8","208d526c.df72ae"]]},{"id":"9e662745.6199d8","type":"debug","z":"d1b19967.2e4e68","name":"query output","active":false,"console":"false","complete":"true","x":877,"y":198,"wires":[]},{"id":"208d526c.df72ae","type":"http request","z":"d1b19967.2e4e68","name":"","method":"POST","ret":"txt","url":"http://localhost:1880/incoming_data","x":1009,"y":79,"wires":[["e48e88e6.1b7178"]]},{"id":"e48e88e6.1b7178","type":"debug","z":"d1b19967.2e4e68","name":"http result","active":false,"console":"false","complete":"payload","x":1192,"y":79,"wires":[]},{"id":"ec61e7da.139e18","type":"function","z":"d1b19967.2e4e68","name":"setup params","func":"msg.queryParameters = msg.queryParameters || {};\nmsg.queryParameters.param1 = 1;\nreturn msg;","outputs":1,"noerr":0,"x":328,"y":74,"wires":[["3bffa50b.c4005a"]]},{"id":"f7a7d4a7.085828","type":"http in","z":"d1b19967.2e4e68","name":"","url":"/incoming_data","method":"post","swaggerDoc":"","x":231,"y":494,"wires":[["7b5aa85e.84a558","ac9432ad.536bd"]]},{"id":"687b82be.97847c","type":"http response","z":"d1b19967.2e4e68","name":"","x":835,"y":510,"wires":[]},{"id":"7b5aa85e.84a558","type":"debug","z":"d1b19967.2e4e68","name":"http input","active":false,"console":"false","complete":"payload","x":450,"y":602,"wires":[]},{"id":"ac9432ad.536bd","type":"function","z":"d1b19967.2e4e68","name":"reply to http call","func":"msg.payload='reply from http';\nreturn msg;","outputs":1,"noerr":0,"x":599,"y":444,"wires":[["687b82be.97847c"]]}]
Version: 0.5.1
Updated 1 year, 1 month ago
License: Apache
36 in the last day
180 in the last week
457 in the last month
  • postgresdb
  • postgres
  • postgres
  • postgresql
  • krisdaniels
