node-red-contrib-pjlink 1.0.1
A PJLink node for Node-RED
npm install node-red-contrib-pjlink
You can send the following commands as a text string in msg.payload
  • on
  • off
  • muteon
  • muteoff
  • getmute
  • getname
  • getmanufacturer
  • getmodel
  • getlamps
  • getinputs
  • getinput
  • getinfo
  • getpowerstate
  • getclass
  • geterrors
You can also set the inputs by sending this object as msg.payload
{"source": 3, "channel": 3}
PJLink specfic errors will be sent to the second output. You can connect to multiple projectors with the same object by specifying msg.host, msg.port and msg.password In this mode the status will not be shown.
See this flow for an example of all the commands.
Version: 1.0.1
Updated 1 month, 3 weeks ago
1 in the last day
25 in the last week
150 in the last month
  • pjlink
  • pjlink
  • natcl
