node-red-contrib-piface-digital 0.0.5
Node-RED nodes to read from and write to a PiFace Digital Raspberry Pi add-on board based on node-pifacedigital
npm install node-red-contrib-piface-digital
Node-RED nodes to control a PiFace Digital add-on board for a Raspberry-Pi using the node implementation node-pifacedigital.
Note: Some later versions of the PiFace relabelled the switch inputs to be 0 - 7 instead of 1 - 8 as on the original boards. We cannot automatically detect this so the user will have to apply some common sense.
Pre-reqs
Please install all prequisites for node-pifacedigital before you install this node: Please consider that the current Version node-pifacedigital on npm only supports node.js >=4.x.x.
On a fresh Raspbian installation you should enable SPI. Therefor start raspi-config and enable SPI under "Advanced Options".
After rebooting you should add your user to the SPI-Group, e.g. for user pi:
usermod -a -G spi pi
Install necessary libraries
git clone https://github.com/piface/libmcp23s17.git
cd libmcp23s17/
make
sudo make install
git clone https://github.com/piface/libpifacedigital.git
cd libpifacedigital/
make
sudo make install
Run the following command in your Node-RED user directory - typically ~/.node-red or `/opt/iobroker/node_modules/iobroker.node-red´on a iobroker installation.
If you get error messages during the installation, try the npm option --unsafe-perm to avoid permission errors.
A pair of input and output Node-RED nodes for the Raspberry Pi PiFace Digital add-on board.
PiFace board number
The hardware address the board must be set with the jumper on the board. To address the boards use the following jumper settings:
Board number JP1 JP2
Address 0 0 0
Address 1 1 0
Address 2 0 1
Address 3 1 1
Output
The PiFace output node will set the selected pin on or off depending on the value passed in. Expects a msg.payload with either a 1 or 0 (or true or false).
Input
The PiFace input node generates a msg.payload with either a 0 or 1 depending on the state of the input pin.
The msg.topic is set to piface/{the pin number}
Version: 0.0.5
Updated 10 years, 1 month ago
3 in the last week
  • rpi-piface-digital in
  • rpi-piface-digital out
  • piface
