node-red-contrib-orvibo-allone 0.1.4
Node-RED node to send IR/RF commands through an Orvibo AllOne
npm install node-red-contrib-orvibo-allone
Node-RED Orvibo AllOne node
This package contains a node to send IR via an Orvibo AllOne
Use npm install node-red-contrib-orvibo-allone to install.
The node appears in the 'devices' category in your Node-RED palette.
Use the config node to set the IP and MAC address of your AllOne.
Learning Codes
Run node learn.js inside the folder to try put your AllOne in learning mode (should glow red if in learning mode).
Press a remote button.
The code should be printed to the screen, then you can copy and paste the code.
Version: 0.1.4
Updated 10 years, 11 months ago
8 in the last week
  • orvibo
  • orvibo-emitir
  • orvibo
  • ir
  • rf
