node-red-contrib-oregon 1.0.4
Oregon scientific radio decoder and sensor nodes for Raspberry pi with RF433 module
npm install node-red-contrib-oregon
npm version
Oregon Scientific radio decoder and sensor Node-RED nodes for Raspberry pi with RF433 module connected.
Pre-requisites
You need to install wiring-pi before use oregonPi node. Refer to the Node-red documentation for details about wiring-pi module.
Hardware
I used the following chip connected to my Raspberry pi 3:
"rf433 module"
I also made a small antenna to the chip using a piece of wire.
Flow example
The following flow example demonstrates how to publish data on charts using oregon nodes (the data to charts also comes from mqtt nodes).
"flow example"
The Oregon pin 27 is listening RF433 module which connected to Raspberry pi 27 pin using GPIO pin numbering. It detects oregon protocol data and outputs it in hexadecimal representation in msg.payload. The details about radio data and message format can be obtained here.
The hexadecimal representation requires conversion to a human readable format. This is done by oregon-decoder node. It outputs the following fields in msg.payload:
  • id - oregon sensor type id
  • sensorName - oregon sensor name
  • channel - channel (1 - 3)
  • rolling - rolling code
  • lowBattery - low battery flag (true / false)
  • data - object with sensor data (depends on sensor type)
The actual temperature and humidity (if particular sensor outputs them) are passed in the msg.payload.data fields. Therefore they should be extracted from the "oregon-decoder" output.
On the flow example this is done by corresponding "temp" and "humi" function nodes. The temp function has the following code (for humidity replace temperature with humidity):
var data = msg.payload;
return {topic: [data.sensorName, data.channel, data.rolling].join('/'), payload: data.data.temperature};
Now the functions outputs can be connected to the appropriate charts or other Node-red nodes.
Version: 1.0.4
Updated 10 years, 5 months ago
  • oregonPi
  • oregon-decoder
  • oregon+scientific
