node-red-contrib-opentimestamps 0.0.7
Node-RED implementation of OpenTimestamps.
A collection of Node-RED nodes use the OpenTimestamps services.
What you mean with opentimestamps?
A timestamping proof standard
OpenTimestamps aims to be a standard format for blockchain timestamping. The format is flexible enough to be vendor and blockchain independent.
OpenTimestamps is a standard for obtain a service with Trustless Timestamps or in other words timestamps secured by the blockchain.
Use npm to command to install this package locally in the Node-RED modules directory
npm install node-red-contrib-opentimestamps
or install in it globally with the command
npm install node-red-contrib-opentimestamps -g
Nodes included in the package
OTS_Stamp create an opentimestamps proof based on the data on buffer msg.fileArray and save the receipt on the buffer msg.otsArray
OTS_Info convert the opentimestamps receipt (taken from msg.otsArray ) in a readable format available on the msg.payload (as a string)
OTS_Upgrade upgrade the receipt available in the buffer msg.otsArray (overwrite the previous content)
OTS_Verify based on the two buffer msg.fileArray and msg.otsArray calculate if a message is valid or not and answer with the result in a readable format on msg.payload
Usage example
A Simple usage of the plugin in Node-RED can be a message broker that work in the following way:
- receive a message from an input queue,
- request the timestamp for the payload and save the receipt from the opentimestamps server,
- create a new message with a JSON with the data of the oringinal payload and the receipt from opentimestamp server,
- send the message on the output queue.
MQTT timestamping broker
The first implementation was a broker for timestamp messages flowing in a MQTT server, the flow of the broker is the part in the red box.
"id": "86aec060.69b3d",
"type": "inject",
"z": "3c8a5604.39f8ba",
"topic": "",
"payload": "bla bla",
"payloadType": "str",
"repeat": "",
"crontab": "",
"once": false,
"x": 90,
"y": 60,
"10ea2927.96f247"
"id": "3a768aaa.e483d6",
"type": "OTS_Stamp",
"name": "OTS_Stamp",
"x": 430,
"y": 260,
"2996139.6165bec",
"208b34b.419b8cc"
"id": "a8e88100.e5485",
"type": "function",
"name": "Convert",
"func": "msg.fileArray = new Buffer(msg.payload);\nmsg.payload = null;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 240,
"y": 260,
"3a768aaa.e483d6"
"id": "2996139.6165bec",
"type": "OTS_Info",
"name": "OTS_Info",
"x": 640,
"y": 300,
"5e5825f7.d0b5ec"
"id": "5e5825f7.d0b5ec",
"type": "debug",
"active": true,
"console": "false",
"complete": "payload",
"x": 850,
"y": 300,
"id": "208b34b.419b8cc",
"type": "function",
"name": "Convert",
"func": "msg.payload = {}\nmsg.payload.data = msg.fileArray;\nmsg.payload.ots = msg.otsArray;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 640,
"y": 220,
"911bbcd8.9ea6"
"id": "630c703c.e22b5",
"type": "mqtt in",
"topic": "ingress_timestamped",
"qos": "2",
"broker": "b2e0c3ab.d24db",
"x": 260,
"y": 480,
"8a4a0f7e.c5b8d"
"id": "10ea2927.96f247",
"type": "mqtt out",
"topic": "ingress",
"qos": "",
"retain": "",
"x": 240,
"y": 60,
"id": "f6c25dc9.0707a",
"type": "mqtt in",
"topic": "ingress",
"qos": "2",
"x": 90,
"y": 260,
"a8e88100.e5485"
"id": "911bbcd8.9ea6",
"type": "mqtt out",
"qos": "",
"retain": "",
"x": 880,
"y": 220,
"id": "1da4a149.b2b18f",
"type": "debug",
"active": true,
"console": "false",
"complete": "true",
"x": 630,
"y": 440,
"id": "912c107d.aa1e7",
"type": "change",
"name": "Get data",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload.data",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 640,
"y": 480,
"c5dc3887.176e88"
"id": "1f918b60.31f315",
"type": "change",
"name": "Get OTS",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload.ots",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 640,
"y": 520,
"1a0710d9.4f655f"
"id": "c5dc3887.176e88",
"type": "function",
"name": "Set filename",
"func": "msg.filename = \"/opt/opentimestamp/dump-mqtt/\" + msg._msgid + \".data\"\nmsg.payload = new Buffer(msg.payload);\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 810,
"y": 480,
"7c6d470.33266b8"
"id": "1a0710d9.4f655f",
"type": "function",
"func": "msg.filename = \"/opt/opentimestamp/dump-mqtt/\" + msg._msgid + \".ots\"\nmsg.payload = new Buffer(msg.payload);\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 810,
"y": 520,
"9b51894d.fb96c8"
"id": "7c6d470.33266b8",
"type": "file",
"filename": "",
"appendNewline": false,
"createDir": false,
"overwriteFile": "true",
"x": 970,
"y": 480,
"id": "9b51894d.fb96c8",
"type": "file",
"filename": "",
"appendNewline": true,
"createDir": false,
"overwriteFile": "false",
"x": 970,
"y": 520,
"id": "8a4a0f7e.c5b8d",
"type": "json",
"x": 450,
"y": 480,
"1da4a149.b2b18f",
"912c107d.aa1e7",
"1f918b60.31f315"
"id": "b2e0c3ab.d24db",
"type": "mqtt-broker",
"z": "",
"broker": "test.mosquitto.org",
"port": "1883",
"clientid": "",
"usetls": false,
"compatmode": true,
"keepalive": "60",
"cleansession": true,
"willTopic": "",
"willQos": "0",
"willPayload": "",
"birthTopic": "",
"birthQos": "0",
"birthPayload": ""
AMQP timestamping broker
The same flow can be implemented using AMQP instead of MQTT with a similar flow.
"id": "c96a6450.746888",
"type": "inject",
"z": "4392d5db.3b662c",
"topic": "",
"repeat": "",
"crontab": "",
"once": false,
"x": 90,
"y": 60,
"d643a206.ef485"
"id": "8d6c59c8.a0e228",
"type": "debug",
"active": true,
"console": "false",
"complete": "true",
"x": 590,
"y": 420,
"id": "58687119.21835",
"type": "amqp in",
"topic": "",
"iotype": "1",
"ioname": "ingress_timestamped",
"server": "22c8fc1b.732854",
"x": 360,
"y": 460,
"8d6c59c8.a0e228",
"1fb75e0f.09efa2",
"a9e5fe7f.6b618"
"id": "d643a206.ef485",
"type": "amqp out",
"routingkey": "",
"iotype": "1",
"ioname": "ingress",
"x": 220,
"y": 60,
"id": "66a83517.6b462c",
"type": "amqp in",
"topic": "",
"iotype": "1",
"x": 90,
"y": 220,
"e5429fd6.1f08e"
"id": "7874c67.2902b38",
"x": 430,
"y": 220,
"7468042d.a8bcdc",
"2421d40d.cc059c"
"id": "e5429fd6.1f08e",
"type": "function",
"name": "Convert",
"outputs": 1,
"noerr": 0,
"x": 240,
"y": 220,
"7874c67.2902b38"
"id": "7468042d.a8bcdc",
"type": "OTS_Info",
"name": "OTS_Info",
"x": 640,
"y": 260,
"54b36dc9.c367a4"
"id": "54b36dc9.c367a4",
"type": "debug",
"active": true,
"console": "false",
"x": 850,
"y": 260,
"id": "2421d40d.cc059c",
"type": "function",
"name": "Convert",
"outputs": 1,
"noerr": 0,
"x": 640,
"y": 180,
"d0f7a135.d2704"
"id": "d0f7a135.d2704",
"type": "amqp out",
"routingkey": "",
"iotype": "1",
"x": 880,
"y": 180,
"id": "1fb75e0f.09efa2",
"type": "change",
"name": "Get data",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 600,
"y": 460,
"48d33270.bb3f0c"
"id": "a9e5fe7f.6b618",
"type": "change",
"name": "Get OTS",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 600,
"y": 500,
"9b07c36e.453f1"
"id": "48d33270.bb3f0c",
"type": "function",
"func": "msg.filename = \"/opt/opentimestamp/dump-amqp/\" + msg._msgid + \".data\"\nmsg.payload = new Buffer(msg.payload);\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 770,
"y": 460,
"b4cdc2a6.e6399"
"id": "9b07c36e.453f1",
"type": "function",
"func": "msg.filename = \"/opt/opentimestamp/dump-amqp/\" + msg._msgid + \".ots\"\nmsg.payload = new Buffer(msg.payload);\nreturn msg",
"outputs": 1,
"noerr": 0,
"x": 770,
"y": 500,
"c56635e0.1f9568"
"id": "b4cdc2a6.e6399",
"type": "file",
"filename": "",
"createDir": false,
"x": 930,
"y": 460,
"id": "c56635e0.1f9568",
"type": "file",
"filename": "",
"createDir": false,
"x": 930,
"y": 500,
"id": "22c8fc1b.732854",
"type": "amqp-server",
"z": "",
"host": "mqtt-broker",
"port": "5672",
"vhost": "",
"keepalive": "30",
"usetls": false,
"verifyservercert": true,
"usetopology": false,
"topology": "{\n\t\"exchanges\": [\n\t\t{\"name\": \"exchange1\", \"type\": \"direct\", \"options\": {\"durable\": false}},\n\t\t{\"name\": \"exchange2\"}\n\t],\n\t\"queues\": [\n\t\t{\"name\": \"queue1\", \"options\": {\"messageTtl\": 60000}},\n\t\t{\"name\": \"queue2\"}\n\t],\n\t\"bindings\": [\n\t\t{\"source\": \"exchange1\", \"queue\": \"queue1\", \"pattern\": \"debug\", \"args\": {}},\n\t\t{\"source\": \"exchange1\", \"exchange\": \"exchange2\", \"pattern\": \"error\"},\n\t\t{\"source\": \"exchange2\", \"queue\": \"queue2\"}\n\t]\n}"
History
- 0.0.2 - 17 May 2017 : First documented version, public available
- 0.0.1 - 15 May 2017 : Initial release developed during the event Hackathon - building layer2 applications that matter
Video of the Hackathon available on YouTube DANGER! It's in Italian! :(
Authors
- Valerio Vaccaro (https://github.com/valerio-vaccaro)
Credits
Node-RED has been made possible by the hard work of Nick O'Leary @knolleary and Dave Conway-Jones @ceejay at IBM Emerging Technology. Much thanks to them and other supporters for advancing this platform. These node use the javascript-opentimestamps library and the opentimestamps public server! Thanks a lot to make it free and open.
This module is developed by Valerio Vaccaro (http://www.valeriovaccaro.it).
