node-red-contrib-openhab2 1.1.8
openhab home automation for node-red
npm install node-red-contrib-openhab2
Description
Nodes facilitating the automation of openHAB ( http://www.openhab.org ) items with Node-RED ( http://nodered.org ).
$ cd ~/.node-red
$ npm install node-red-contrib-openhab2
- openhab2-controller
Configuration node for communication with an openHAB controller.
Configuration:
  • Name : Specify a name for the configuration node
  • Protocol : "http" or "https"
  • Host : Specify the hostname or ip address
  • Port : (Optionally) Specify the ip port
  • Path : (Optionally) Specify the additional base path
  • Username : (Optionally) Specify the username to authenticate
  • Password : (Optionally) Specify the password to authenticate
- openhab2-in
Listens to state changes of a selected openHAB Item.
Configuration:
  • Name : Optionally specify a name
  • Controller : Select the openHAB controller
  • Item : Select the Item to monitor
Messages injected in NodeRED flows (2 channels):
Channel 1:
  • msg.item : the item's itemname (not label)
  • msg.topic : "StateEvent"
  • msg.payload : the new state of the selected item
Channel 2:
  • msg.topic : "RawEvent"
  • msg.payload : raw (unprocessed) event for the selected item
- openhab2-monitor
Monitors the openhab2-controller node.
Configuration:
Messages injected in NodeRED flows (3 channels):
Channel 1:
  • msg.topic : "ConnectionStatus"
  • msg.payload : connection status ('ON' or 'OFF')
Channel 2:
  • msg.topic : "ConnectionError"
  • msg.payload : error message
Channel 3:
  • msg.payload : raw (unprocessed) event for all items
- openhab2-out
Sends commands or state updates to a selected openHAB Item. E.g. "ON", "OFF", "REFRESH", ...
Configuration:
  • Item : Optionally select the Item to address. If specified, it overrides the item specified in the incoming message.
  • Topic : Optionally select "ItemCommand" or "ItemUpdate". If specified, it overrides the topic specified in the incoming message.
  • Payload : Optionally specify the command or update value to send to the selected item. If specified, it overrides the payload specified in the incoming message.
Messages accepted by NodeRED flows:
  • msg.item : optionally the Item to address
  • msg.topic : optionally "ItemCommand", "ItemUpdate"
  • msg.payload : optionally the fixed command or update value to send to the selected item
Messages injected in NodeRED flows (1 channel):
Channel 1: if output is successful, the input message is copied to this channel.
- openhab2-get
Gets an openHAB Item on an input message.
Configuration:
  • Item : Optionally select the Item to get. If specified, it overrides the item specified in the incoming message.
Channel 1: The input message with addition of :
  • msg.payload : the item object (name, label, state, ...)
  • msg.payload_in : copy of incoming message's payload
Release notes
v1.1.4
  • paletteLabel defined for all nodes
  • openhab2-out now outputs the input message in case of success
  • Allow user to filter a long list of OpenHAB items by typing in (a part of) itemname. (Case-insensitive)
Version: 1.1.8
Updated 3 years, 7 months ago
Rating: 2.3 3
9 in the last week
  • openhab2-controller
  • openhab2-in
  • openhab2-get
  • openhab2-monitor
  • openhab2-out
  • openhab2-events
  • openhab2
