node-red-contrib-offline 0.1.2
A node that reports when data has not arrived in a configurable period of time
npm install node-red-contrib-offline
Reports when data has not arrived in a configurable time
You can find source code and more information here:
Use this node to monitor a message stream and report if data does not arrive in a configurable time. This provides a good way to tell if a device has gone off-line.
The timer starts on startup and is reset every time a message arrives. If the time expires with no data arriving, the most recently received message is sent to the output. If no message was ever received, a new message is sent with the default topic and a payload of "false".
Settings
  • Name - The name to display for this node. Leave blank to use the default.
  • Time - The allowable gap between messages, in seconds. If no data arrives before the timer expires, the most recent message (or a default message) is sent to the output.
Settings
  • Default Topic - The topic that will be used to generate a message on timeout if no packet was ever received.
Status
While it is running, the node displays its status:
  • 'No data' - No messages have been received.
  • 'Offline' - The timeout has expired without a message arriving.
  • 'OK' - The message source is on-line and messages are being received.
Version: 0.1.2
Updated 7 months ago
5 in the last day
11 in the last week
68 in the last month
  • offline
  • clough42
