node-red-contrib-odbc 1.0.4
Node for node-red to unixODBC and its supported drivers. (MS SQL, PostgreSQL, ...)
npm install node-red-contrib-odbc
Node for Node-RED to unixODBC and its supported drivers. Based on node-odbc https://github.com/wankdanker/node-odbc
Requirements
  • unixODBC binaries and development libraries for module compilation
    • on Ubuntu/Debian sudo apt-get install unixodbc unixodbc-dev
    • on OSX using macports.org sudo port unixODBC
  • odbc drivers for target database
  • properly configured odbc.ini and odbcinst.ini.
Expample of odbcinst.ini
    [PostgreSQL]
    Description=ODBC for PostgreSQL
    Driver=/usr/lib/psqlodbc.so
    Setup=/usr/lib/libodbcpsqlS.so
    FileUsage=1
    [MySQL]
    Description=ODBC for MySQL
    Driver=/usr/lib/libmyodbc5.so
    Setup=/usr/lib/libodbcmyS.so
    FileUsage=1
    [FreeTDS]
    Description=ODBC for MS SQL
    Driver=/usr/lib64/libtdsodbc.so.0
    [MSSQL]
    Description=Microsoft ODBC Driver 11 for SQL Server
    Driver=/opt/microsoft/msodbcsql/lib64/libmsodbcsql-11.0.so.2270.0
    Threading=1
    UsageCount=1
After insuring that all requirements are installed run the following command in the root directory of your Node-RED install
Configure node
####Connection string
Config
####Query
Config
You can uses the mustache format.
Version: 1.0.4
Updated 1 year, 7 months ago
10 in the last day
31 in the last week
103 in the last month
  • ODBC-CN
  • ODBC
  • odbc
  • unixodbc
  • mssql
  • mysql
  • sql
  • PostgreSQL
  • efa2000
