node-red-contrib-objectstore 0.0.31
Node-Red Nodes for IBM Bluemix Object Storage service.
npm install node-red-contrib-objectstore
A Node-RED node to store, delete and restore objects from the IBM Bluemix object storage service.
Run the following command in the root directory of your Node-RED install or home directory (usually ~/.node-red) and will also install needed libraries.
This node was tested under Nodejs V4.x LTS and NPM 2.x on NodeRed.
Provides a few nodes to easily manage the containers and objects for the IBM Bluemix Object Storage service. Your can specify the credentials from the Service if you run local on a device (e.g. Raspberry Pi with the provided credentials) or it will use the VCAP_SERVICES on Bluemix.
There are two regions (access points) supported:
This node helps to deliver images and audio files as a payload (up to 5MB) via the REST API Interface of Swift.
Object Storage Put
Saves the given object to the IBM Object Storage Service into the given container. This also will create the container if not existing (with public viewable rights).
Object Storage Get
Restores the object from the IBM Object Storage Service as a payload or a local file.
Object Storage Del
Deletes the given object of the given container from the IBM Object Storage Service.
Version: 0.0.31
Updated 10 years, 6 months ago
15 in the last week
  • os-get
  • os-put
  • os-del
  • os-config
  • ibm
  • bluemix
  • object
  • storage
  • openstack
  • object storage
