node-red-contrib-objectid 1.1.0
Node-RED node to create an Object-Id for mongodb operations.
npm install node-red-contrib-objectid
Platform Node-RED Contribution Bit NodeJS_Version Standard - JavaScript Style Guide NPM download NPM version Build and publish Gitpod Ready-to-Code
This Node-Red node is to create an Object-Id for mongodb write operations from JSON inputs.
flowshot
The selected property in msg.payload or in Array-Objects will be set to a BSON-Object-Id, you can also inject a 24 hex characters and the node creates a valid Object-Id property from it or raise an error if it is not valid.
For example:
msg.payload._id = "572dbc06f307c8682045c55c"
or
msg.payload.uuid = "572dbc06f307c8682045c55c"
If the target property is not to find or empty, then a random Object-Id is created.
Test flows
Flow example
Config
flowsprops
Examples
flowsres
flowsres2
flowsres3
License:
MIT: THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Version: 1.1.0
Updated 1 year, 9 months ago
63 in the last week
  • objectid
  • database
  • object-id
  • mongodb
  • biancoroyal
