node-red-contrib-npm 1.0.2
Node-RED node to dynamically expose NPM modules as nodes.
npm install node-red-contrib-npm
Node-RED node allowing NPM modules to be dynamically exposed as custom nodes.
From your Node-RED directory:
Open the Editor panel to configure the NPM module to expose. NPM module name must the package identifier in the NPM registry. When the flow is deployed, the package will be automatically downloaded and installed. Status information will show you when the node is ready to receive messages.
Using the editor panel, the node can be configured to execute the module constructor, function property or a custom setup code when receiving messages. The msg.payload property from incoming messages will be passed in as the sole argument to the function.
Results from the function execution will be set as msg.payload. The node currently supports passing results from following function invocation patterns.
  • Function Returns Primitive Type (String, Boolean, Array).
  • Function Returns Promise.
  • Results passed through a Callback.
For Promise or Callback results, messages will be sent when the results are available.
Version: 1.0.2
Updated 6 years, 1 month ago
73 in the last week
  • npm
  • npm
  • nodejs
  • javascript
  • modules
