node-red-contrib-neuralnetwork 0.1.1
SmartNode node package, provided by MakerCollider
npm install node-red-contrib-neuralnetwork
Download node-red-contrib-neuralnetwork to nodered root directory.
Windows for example: C:\node-red\node_modules
Linux for example: /home/root/node-red/node_modules
You will need to restart Node-RED for it to pick-up the new nodes.
node-red-contrib-neuralnetwork is based on brain. You need to see it basic usage at first.
Train
When there is no msg.netJSON input, brain node will train with msg.trainData and output net.toJSON in msg.net.
Run
When there is msg.netJSON input, brain node will not train anymore. Instead, it will directory run net.run() with your msg.runData. And output the result in msg.payload.
Example
Train:
[{"id":"d4a484b.f2b5b78","type":"debug","z":"46d50fa1.b92af","name":"","active":true,"console":"false","complete":"net","x":679,"y":175,"wires":[]},{"id":"3b4d60b3.c4b2a","type":"inject","z":"46d50fa1.b92af","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":150,"y":144,"wires":[["6d766489.92899c"]]},{"id":"6d766489.92899c","type":"function","z":"46d50fa1.b92af","name":"fake data","func":"// This function return a fake json array\nvar trainData = [{input: { r: 0.03, g: 0.7, b: 0.5 }, output: { black: 1 }},\n           {input: { r: 0.16, g: 0.09, b: 0.2 }, output: { white: 1 }},\n           {input: { r: 0.5, g: 0.5, b: 1.0 }, output: { white: 1 }}]\n\nmsg.trainData = trainData\nreturn msg;","outputs":1,"noerr":0,"x":333,"y":183,"wires":[["2fe2efbc.d01d1"]]},{"id":"2fe2efbc.d01d1","type":"neuralNetwork","z":"46d50fa1.b92af","name":"neuralNetwork","learningRate":0.3,"errorThresh":0.005,"iterations":20000,"log":false,"logPeriod":10,"x":516,"y":185,"wires":[["d4a484b.f2b5b78"]]}]
Run:
[{"id":"10d56f1d.ef2a91","type":"debug","z":"46d50fa1.b92af","name":"","active":true,"console":"false","complete":"payload","x":687,"y":346,"wires":[]},{"id":"808a1160.7f75f","type":"inject","z":"46d50fa1.b92af","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":131,"y":325,"wires":[["fbed5f0e.0412a"]]},{"id":"fbed5f0e.0412a","type":"function","z":"46d50fa1.b92af","name":"fake data","func":"// This function return a fake json array\nvar netJSON = {\"layers\":[{\"r\":{},\"g\":{},\"b\":{}},{\"0\":{\"bias\":0.5976173927716023,\"weights\":{\"r\":3.5006895738532835,\"g\":-4.542455700505483,\"b\":0.9988932386815509}},\"1\":{\"bias\":0.6470978455858952,\"weights\":{\"r\":3.6115725201557827,\"g\":-4.875546614413311,\"b\":1.211740813346471}},\"2\":{\"bias\":-0.3559477465736521,\"weights\":{\"r\":1.1063595019849224,\"g\":-1.857026678772011,\"b\":0.14886809335684345}}},{\"black\":{\"bias\":3.3336645409591017,\"weights\":{\"0\":-3.7876606581596914,\"1\":-4.023316483216229,\"2\":-1.0819957068479935}},\"white\":{\"bias\":-3.29149645757729,\"weights\":{\"0\":3.782751737648757,\"1\":4.173873416865656,\"2\":0.7154074171638515}}}],\"outputLookup\":true,\"inputLookup\":true}    \nvar runData = { r: 1, g: 0.4, b: 0 }\n\nmsg.runData = runData\nmsg.netJSON = netJSON\nreturn msg;","outputs":1,"noerr":0,"x":315,"y":336,"wires":[["3132e68b.cecd1a"]]},{"id":"3132e68b.cecd1a","type":"neuralNetwork","z":"46d50fa1.b92af","name":"neuralNetwork","learningRate":0.3,"errorThresh":0.005,"iterations":20000,"log":false,"logPeriod":10,"x":501,"y":341,"wires":[["10d56f1d.ef2a91"]]}]
MIT License \ No newline at end of file
Version: 0.1.1
Updated 8 years, 6 months ago
1 in the last week
  • neuralNetwork
  • multiInData
  • dataCollect
  • outputJudge
  • node
  • neuralnetwork
  • makercollider
