node-red-contrib-netatmo-dashboard 1.0.0
Get JSON payload for NetAtmo dashboard. See http://netatmo.com, https://dev.netatmo.com/doc
Node-RED node to fetch all data (temperature, pressure, humidity, co2, noise, etc) from a NetAtmo device.
Returns a payload which is split up into to parts:
- a compact object which contains the most relevant information
- a detailed object which contains the complete return from the netatmo api
Attention: The reachable status of the complete station seems not to changefor at least a couple of hours. While the reachable status of devices change after approximately 1h, the station itselve will shown as reachable even if this is not the case
An Example:
"compact":
"outdoor":
"reachable": true,
"temperature":15.1,
"humidity":86,
"temperatureTrend":"down",
"battery_percent":15,
"rf_status":47
"rain":
"reachable": true,
"rain":0,
"sum_rain_24":0.4,
"sum_rain_1":0.101,
"battery_percent":45,
"rf_status":40
modules:
data_type: [ 'Temperature', 'CO2', 'Humidity' ],
"battery_percent": 14,
"rf_status": 80,
"reachable": true,
"dashboard_data":
"time_utc": 1545901333,
"Temperature": 23.1,
"CO2": 1555,
"Humidity": 50,
"min_temp": 22.7,
"max_temp": 23.6,
"date_min_temp": 1545866372,
"date_max_temp": 1545896155,
"temp_trend": 'stable'
"temperature": 23.1,
"Humidity": 50,
"CO2": 1555,
"min_temp": 22.7,
"max_temp": 23.6,
"date_max_temp": 1545896155 },
"name": 'Kinderzimmer',
"data_type": [ 'Temperature', 'CO2', 'Humidity' ],
"battery_percent": 45,
"rf_status": 70,
"reachable": true,
"dashboard_data":
"time_utc": 1545901314,
"Temperature": 23.2,
"CO2": 1258,
"Humidity": 48,
"min_temp": 23,
"max_temp": 23.6,
"date_min_temp": 1545888753,
"date_max_temp": 1545865225,
"temperature": 23.2,
"Humidity": 48,
"CO2": 1258,
"min_temp": 23,
"max_temp": 23.6,
"name": 'Schlafzimmer',
"data_type": [ 'Temperature', 'CO2', 'Humidity'],
battery_percent: 80,
"rf_status": 68,
"reachable": true,
"dashboard_data":
"Temperature": 22.7,
"CO2": 1497,
"Humidity": 56,
"min_temp": 22.5,
"max_temp": 22.8,
"date_min_temp": 1545865225,
"date_max_temp": 1545885422,
"temperature": 22.7,
"Humidity": 56,
"CO2: 1497",
"min_temp": 22.5,
"max_temp": 22.8,
"temperature":28.9,
"co2":704,
"humidity":43,
"noise":43,
"pressure":1021.3,
"pressureTrend":"down",
"station_name":"Netatmo#Main",
"last_status_store":1536857210,
"reachable": true,
"detailed":
"_id":"70:ee:50:02:be:56",
"cipher_id":"{your_cypher}",
"date_setup":1397226153,
"last_setup":1397226153,
"type":"NAMain",
"module_name":"Office",
"firmware":132,
"last_upgrade":1440050083,
"wifi_status":26,
"co2_calibrating":false,
"data_type":["Temperature","CO2","Humidity","Noise","Pressure"],
"place":{"altitude":36,"city":"Berlin","country":"DE","timezone":"Europe/Berlin","location":[{lat},{long}]},
"dashboard_data":
"time_utc":1536857196,
"Temperature":28.9,
"CO2":704,
"Humidity":43,
"Noise":43,
"Pressure":1021.3,
"AbsolutePressure":1017,
"min_temp":27.2,
"max_temp":31.9,
"date_min_temp":1536821144,
"date_max_temp":1536813686,
"temp_trend":"up",
"pressure_trend":"down"
"modules":
"_id":"03:00:00:00:db:38",
"type":"NAModule4",
"module_name":"wohnzimmer",
"data_type":["Temperature","CO2","Humidity"],
"last_setup":1397227514,
"dashboard_data":
"time_utc":1536856881,
"Temperature":26,
"CO2":680,
"Humidity":44,
"min_temp":25.4,
"max_temp":26.8,
"date_min_temp":1536828835,
"date_max_temp":1536791560,
"temp_trend":"stable"
"firmware":44,
"last_message":1536857208,
"last_seen":1536856881,
"rf_status":89,
"battery_vp":5196,
"battery_percent":55
"_id":"02:00:00:02:cb:2e",
"type":"NAModule1",
"module_name":"Outdoor",
"data_type":["Temperature","Humidity"],
"last_setup":1397226241,
"dashboard_data":
"time_utc":1536857170,
"Temperature":15.1,
"Humidity":86,
"min_temp":13.4,
"max_temp":17.6,
"date_min_temp":1536818729,
"date_max_temp":1536846917,
"temp_trend":"down"
"firmware":44,
"last_seen":1536857170,
"rf_status":47,
"battery_vp":3968,
"_id":"03:00:00:01:0a:a4",
"type":"NAModule4",
"module_name":"Kinderzimmer",
"last_setup":1399312524,
"dashboard_data":
"time_utc":1536857157,
"Temperature":26.4,
"CO2":721,
"Humidity":42,
"min_temp":25.4,
"max_temp":27.6,
"date_min_temp":1536829474,
"date_max_temp":1536789645,
"firmware":44,
"last_seen":1536857208,
"rf_status":60,
"battery_vp":5313,
"battery_percent":62
Authentication
NetAtmo changed the authentication scheme in October 2022, in order to authenticate with your device you will need to create an application in Netatmo Connect and obtain: client_id, client_secret and refresh_token. To get the refresh_token a OAuth2 client is needed (i.e. Paw for MacOS): use these params
- client_id: from your app in Netatmo Connect
- client_secret: from your app in Netamo Connect
- Authorization URL: https://api.netatmo.com/oauth2/authorize
- Access URL: https://api.netatmo.com/oauth2/token
- Redirect URL: http://localhost
Click on Get token and then on the input box of Refresh token.
The MIT License
