node-red-contrib-mysensors 4.2.0
Mysensors related nodes, for decoding / encoding mysensors serial protocol and MQTT topic, and wrapping arbitrary messages into mysensors compatible messages
npm install node-red-contrib-mysensors
Quality Gate Status Sonar cloud test
A node-RED mysensors protocol decoder / encoder / wrapper package, including basic controller functionality Contains a node to decode / encode mysensors serial protocol to / from node-red messages, and a node for adding mysensors specific data like sensor type, nodeid etc. which can then be sent to mysensors network
Within your local installation of Node-RED run:
Once installed, restart your node-red server, and you will have a set of new nodes available in your palette under mysensors:
Node-RED mysdecode
This decodes the mysensors serial protocol packages or a MQTT topic from a mysensors MQTT gateway, and enriches the Node-RED msg object with the following extra data:
msg.payload // Payload data from sensor network
msg.nodeId // node of the origin
msg.childSensorId
msg.messageType
msg.ack
msg.subType
msg.messageTypeStr
msg.subTypeStr
The last two parameters are text representations for message type and sub type. No other mysensros node is actively using these values.
see mysensors API v2.x for more info on the different parts
The following nodes will be able to use these properties to interact with the messages from the mysensors network
Node-RED mysencode
This encodes a message into either mysensors serial, or a mysensors mqtt topic.
If using MQTT, then set topicRoot on the message, before sending it into this node, in order to set your own root topic, or set it in the node to set the topicRoot like
topicRoot/nodeId/childSensorId/ack/subType
Node-RED mysencap
This will add the message properties mentioned under mysdecenc to the message object of an existing Node-RED message. By sending the output through mysencode, you can create a message that can be sent to your sensor network, or sent to another controller that understands MySensors serial protocol or MQTT topic format.
If you want to send it to another controller as a serial port format, use socat for creating a dummy serial port (on linux):
socat PTY,link=/dev/ttyS80,mode=666,group=dialout,raw PTY,link=/dev/ttyUSB20,mode=666,group=dialout,raw &
Now use /dev/ttyS80 in a serial port node in node-red, and use /dev/ttyUSB20 in your chosen controller.
Node-RED mysdebug
This will decode the mysensors serial protocol payload, and enrich it with descriptions of sensor types etc. Meant as a debugging tool. Data will be sent out of the node, and can be used in a debug node, or dumped to disk, for file logging
Node-RED myscontroller
This node can handle ID assignment to nodes on your network. Will respond with a new ID everytime it sees a request for an ID from a node.
The node uses node-red context for storage, which is normally in memory only, and is reset on every startup of your node-red instance. You can configure a filesystem context as well in your node-red settings.js file:
    contextStorage: {
        default: "memoryOnly",
        memoryOnly: {
            module: "memory",
        file: { module: 'localfilesystem' }
In this example node-red defaults to memory (keeping things as is), and in addition it creates a secondary localfile storage (called file) which you can then set the myscontroller node to use for persistent data storage. Checkout node-red documentation on context
The data is kept as a object on a single key entry in the context
The controller keeps track of when it hears the nodes, sketch name / version reported during presentation etc. and will be shown when you look at the configuration page of the node.
Version: 4.2.0
Updated 3 years ago
License: GPL-2.0
1843 in the last week
  • mysdecode
  • mysencode
  • mysencap
  • mysdebug
  • myscontroller
  • mysensorsdb
  • mysensors
  • decode
  • encode
  • wrap
  • encapsulate
  • debug
