node-red-contrib-multiproject 0.0.2-14
Multiproject for node-red
Node-RED Multiproject
This node-red package extension transform node-red in a mutiproject mode. We can group several flows in a set called project and manage different projects at the same time.
This extension add the project name and a new visual combo list in the header of the node-red editor where we can create a new project, remove or select one. To change the default name of the project double click in the project tittle and fill the name of it.
To install the node-red package extension:
npm install node-red-contrib-multiproject
To manage the relation between the projects and the flows, we add a new invisible node with a new type called 'project' in the default file of node-red, where we can mantein the name and the flow nodes of it.
And example of this node could be:
"id" : "577e736dccf2bb09e469c910",
"type":"project",
"flows":["6bf4a987.6cf088", "5c94cd6b.bd9a44"],
"name" : "Mqtt Project"
Contributors: Miguel Angel Salinas (miguel@thingtrack.com) Company: Thingtrack s.l
