node-red-contrib-mqtt-broker 0.2.9
MQTT Broker server on Node-RED
npm install node-red-contrib-mqtt-broker
Not maintained anymore because dependant Mosca is not maintained. Please check node-red-contrib-aedes node instead of that.
Because this MQTT broker is implemented by Node.js, you can use MQTT-in and MQTT-out nodes without MQTT environment like Mosquitto.
Build Status
Dependency Status devDependency Status
Open Source Love
Flows
Once you just put this node on Node-RED and hit deploy button, MQTT Broker will run on your Node-RED.
flows
You can set "localhost" in MQTT-in and MQTT-out properties as follows.
setting
In the "manage palette", Node-RED users can install the node using "mqtt-broker" as the keyword.
ga
Version: 0.2.9
Updated 3 years, 9 months ago
Rating: 4.0 5
301 in the last week
  • mosca in
  • mosca
  • mqtt
  • Jochen Scheib
