node-red-contrib-modbus 5.31.0
The all in one Modbus TCP and Serial contribution long term supported package for Node-RED.
npm install node-red-contrib-modbus
Platform Node-RED Contribution Modbus Financial Contributors on Open Collective NPM version ES_Sourdce_Version ES_Deploy_Version NodeJS_Version Standard - JavaScript Style Guide NPM download Build and publish Codacy Badge Gitpod Ready-to-Code
The all-in-one Modbus TCP and Serial contribution package for Node-RED
nodemodbus64
International IIoT Website for Node-RED
For an international area, Iniationware has provided the PLUS for Node-RED International website.
IIoT Webseite Deutschland für Node-RED
Für einen deutschsprachigen Bereich hat Iniationware die Webseite PLUS for Node-RED Germany bereitgestellt.
Contribution Information
Node-RED contribution package for Modbus version overview:
Based on modbus-serial with TCP, C701, Telnet, Serial, RTU buffered, and ASCII
  • stress tested with Node-RED v1.0.4 and Node.js LTS
  • works with queueing per unit and round robin scheduling
Node-RED v3.x versions:
  • Node.JS 18.x will be supported with v5.22+
  • Node.JS 16.x will be supported with v5.22+
Node-RED v2.x versions:
  • Node.JS 16.x will be supported with v5.20+
  • Node.JS 14.x is supported with v5.14+
  • Node.JS 12.x is supported with v5.x
Node-RED v1.x versions:
  • Node.JS 14.x is supported with v5.14.+
  • Node.JS 10.x is supported with v5.x
Node-RED v0.x versions:
  • Node.JS 10.x is supported with v4.x
  • Node.JS 8.x is supported with v3.x
  • Node.JS 6.x is supported with v2.x
  • Node.JS 4.x is supported with v1.x
If you like that contributor's package for Modbus, then please give us your star at GitHub !
Run the following command for global install
npm install -g node-red-contrib-modbus
try these options on npm install to build, if you have problems to install
--unsafe-perm --build-from-source
modbus-serial, serialport and jsmodbus
The serialport optional dependency is just to list all ports on your system in the client configuration. It is not the serialport version to work with Modbus at runtime. For that check the modbus-serial or jsmodbus package.json, please! The modbus-serial supports and works for TCP connections in that package, too. The jsmodbus package is just to provide a simple Modbus Server node. All Modbus commands running on modbus-serial.
TCP or Serial testing
If you get in trouble with TCP connections, then check and test with just modbus-serial first, please!
If you get in trouble with Serial connections, then check with just serialport first, please!
Update/Upgrade/Downgrade
To update the dependencies or the whole package, you have just to install again.
npm show node-red-contrib-modbus@* version
To get a special version please set the version with @M.M.F:
npm install [email protected]
or global by
npm install -g [email protected]
How to use
Flow Example
Errors
Since v5.22+ the package will catch network and other errors of the client and server node. That means, you have to handle the error status of the node and Node-RED should not crash in the handled cases.
Debug
Debug will be activated by starting Node-RED with debug mode:
DEBUG=contribModbus*,modbus-serial node-red -v
or
DEBUG=contribModbus:{option},contribModbus:{option},...
see Wiki pages to get more options in detail
Contributing
Let's work together! Contributors are welcome. Please, fork the repo and send your pull requests from your repo to our develop branch or open issues while you're testing!
For Developers
See the scripts of the package and the additional Shell scripts to clean, update, or upgrade this NPM package.
  • dev-link (local testing with Node-RED)
  • testing (unit, integration)
  • coverage
  • docs generation
  • standard-version alpha, beta, release
  • git-flow
For Testers
Report issues, share your experiences, record tutorials, write Wiki articles and Blogs to share more about this package, please!
Authors
since April 2016 by Klaus Landsdorf and Community Driven
History
Code Contributors
This project exists thanks to all the people who contribute. [Contribute].
Become a financial contributor and help us sustain our community. [Contribute]
Individuals
Organizations
Support this project with your organization. Your logo will show up here with a link to your website. [Contribute]
Version: 5.31.0
Updated 3 days ago
License: BSD-3-Clause
Rating: 4.8 40
3915 in the last week
  • modbus-client
  • modbus-response
  • modbus-read
  • modbus-getter
  • modbus-flex-getter
  • modbus-write
  • modbus-flex-write
  • modbus-server
  • modbus-flex-server
  • modbus-queue-info
  • modbus-flex-connector
  • modbus-io-config
  • modbus-response-filter
  • modbus-flex-sequencer
  • modbus-flex-fc
  • plusfornodered
  • modbus
  • automation
  • biancoroyal
