node-red-contrib-mobius-flow-lighting 1.0.2
Node-RED lighting control nodes for Mobius Flow
Copyright 2016 Interior Automation under the BSD-3-Clause license.
A collection of Node-RED nodes for lighting control.
This module includes nodes providing the logic for various control regime types such as local control
, daylight harvesting
, time control
and various conditioning nodes to aid in converting signals from devices such as switches
and PIRs
to be compatible with the control regime nodes.
npm install node-red-contrib-mobius-flow-lighting
Conditioning Nodes
Switch-On
Evaluates a configurable boolean
value in the payload and converts it to a sw-on
or dim-up-start
message to indicate to a control regime than an ON
switch has been pushed or held.
Switch-Off
value in the payload and converts it to a sw-off
or dim-dn-start
message to indicate to a control regime than an OFF
Switch-Toggle
value in the payload and converts it to a sw-toggle
or dim-bi-start
message to indicate to a control regime than a TOGGLE
PD
value in the payload and converts it to a pd-presence
message to indicate to a control regime than a PD has detected PRESENCE
Control Regime Nodes
Control regime nodes take some form of trigger
and provide a lighting level
output based on their internal logic.
Local Control
A simple control regime for offices, stairwells, breakout areas, toilets etc. This control regime takes switches and PDs as inputs and sets the lighting output to the Activated
level for a period of time, after which it drops back to the Dormant
level. An optional Warning
level can be set with its own timeout to indicate that if no further triggers are received the Dormant
level will be set. It is possible to to disable all timers for areas requiring a simple ON/OFF
switch.
If PDs are used they can be set to Absence Only
mode. This is useful in meeting rooms in presentation mode, where a switch is used to turn the lights on and off. The lights will remain on while there are people in the room but automatically switch off after a period of absence, but do not switch on when a PD is triggered.
This control regime does not support manual dimming.
Manual Dimming Control
A manual dimming control regime for offices, meeting rooms etc. This control regime takes switches and PDs as inputs and sets the lighting output to the Activated
level. It is possible to to disable all timers for areas requiring a simple ON/OFF
switch.
A 'quick' push of the ON or OFF side of the switch will set the lights to the Activated
or Dormant
levels and holding the ON or OFF side of the switch will dim the zone up or down. Releasing the switch during dimming will set the new Activated
level.
If a TOGGLE switch is used the lights will toggle ON or OFF for a short push and dim up or down for a long push. The dim direction is determined by the current level.
Time Control
Not yet implemented.
Daylight Harvesting
Updates
Version 0.0.2
Conditioning nodes now have a green status dot for one second to indicate that they were triggered.
