node-red-contrib-mobius-flow-bcm 1.2.0
Node-RED control nodes for Mobius Flow on the IA BCM
npm install node-red-contrib-mobius-flow-bcm
Version
Copyright 2016 Interior Automation under the BSD-3-Clause license.
A collection of Node-RED nodes for controlling the IA Building Control Module (BCM).
npm install node-red-contrib-mobius-flow-lcm
This module requires node-red-contrib-mobius-flow-base to be installed.
BCM IN
This node publishes raw command from the BCM
Version: 1.2.0
Updated 6 years, 4 months ago
License: BSD-3-Clause
1 in the last week
  • bcm in
  • bcm out
  • bcm get digital in
  • bcm get rtd in
  • bcm get analog in
  • bcm set analog out
  • bcm set digital out
  • bcm dali multi sensor
  • bcm dali pir
  • bcm dali lux sensor
  • bcm set dali level
  • mobius
  • mobius flow
  • lighting
  • lighting control
  • lighting control module
  • building control module
  • BCM
  • LCM
  • BMS
