node-red-contrib-milight-wrapper 1.0.0
A Node-RED node to control the MiLight family (limitless led, easybulb) of light.
A Node Red nodes to control White and Color Milight LED bulbs and OEM equivalents such as Rocket LED, Limitless LED Applamp, Easybulb, s'luce, iLight, iBulb, and Kreuzer.
npm i node-red-contrib-milight
Example Flow
[{"id":"703feba3.f74ba4","type":"MiLight","z":"cedb2490.c23188","name":"White Milight Bulb","bulbtype":"white","zone":1,"ip":"192.168.0.21","broadcast":true,"x":602.5,"y":175,"wires":[]},{"id":"ea754d8b.c0a0a","type":"MiLight","z":"cedb2490.c23188","name":"Color Milight Bulb","bulbtype":"white","zone":1,"ip":"192.168.0.21","broadcast":true,"x":625.5,"y":488,"wires":[]},{"id":"9aa84473.6753f8","type":"inject","z":"cedb2490.c23188","name":"Off","topic":"","payload":"off","payloadType":"str","repeat":"","crontab":"","once":false,"x":148.5,"y":432,"wires":[["ea754d8b.c0a0a"]]},{"id":"ee46f786.9dfcd8","type":"inject","z":"cedb2490.c23188","name":"On","topic":"","payload":"on","payloadType":"str","repeat":"","crontab":"","once":false,"x":152.5,"y":485,"wires":[["ea754d8b.c0a0a"]]},{"id":"994c5f75.f75a5","type":"inject","z":"cedb2490.c23188","name":"white","topic":"","payload":"white","payloadType":"str","repeat":"","crontab":"","once":false,"x":149.5,"y":539,"wires":[["ea754d8b.c0a0a"]]},{"id":"f6ea5afe.d758b8","type":"inject","z":"cedb2490.c23188","name":"Brightness","topic":"","payload":"10","payloadType":"num","repeat":"","crontab":"","once":false,"x":145.5,"y":610,"wires":[["44621f47.abc8f"]]},{"id":"44621f47.abc8f","type":"function","z":"cedb2490.c23188","name":"","func":"msg.command = 'brightness';\nreturn msg;","outputs":1,"noerr":0,"x":320.5,"y":610,"wires":[["ea754d8b.c0a0a"]]},{"id":"d2630aff.f36b38","type":"inject","z":"cedb2490.c23188","name":"Color","topic":"","payload":"20","payloadType":"num","repeat":"","crontab":"","once":false,"x":138.5,"y":668,"wires":[["1341915.7fd236f"]]},{"id":"1341915.7fd236f","type":"function","z":"cedb2490.c23188","name":"","func":"msg.command = 'color';\nreturn msg;","outputs":1,"noerr":0,"x":319.5,"y":669,"wires":[["ea754d8b.c0a0a"]]},{"id":"8ea9e947.32c7c8","type":"inject","z":"cedb2490.c23188","name":"On","topic":"","payload":"on","payloadType":"str","repeat":"","crontab":"","once":false,"x":141.5,"y":36,"wires":[["703feba3.f74ba4"]]},{"id":"9d1a4225.3a926","type":"inject","z":"cedb2490.c23188","name":"Off","topic":"","payload":"off","payloadType":"str","repeat":"","crontab":"","once":false,"x":141,"y":78,"wires":[["703feba3.f74ba4"]]},{"id":"ddc3d3e9.af25","type":"inject","z":"cedb2490.c23188","name":"Warmer","topic":"","payload":"warmer","payloadType":"str","repeat":"","crontab":"","once":false,"x":144.5,"y":128,"wires":[["703feba3.f74ba4"]]},{"id":"6d5e9f9d.72a17","type":"inject","z":"cedb2490.c23188","name":"Cooler","topic":"","payload":"cooler","payloadType":"str","repeat":"","crontab":"","once":false,"x":146,"y":176,"wires":[["703feba3.f74ba4"]]},{"id":"9ef7721c.7ae64","type":"inject","z":"cedb2490.c23188","name":"Bright Up","topic":"","payload":"bright_up","payloadType":"str","repeat":"","crontab":"","once":false,"x":157.5,"y":224,"wires":[["703feba3.f74ba4"]]},{"id":"88a65d6.31e7ba","type":"inject","z":"cedb2490.c23188","name":"Bright Down","topic":"","payload":"bright_down","payloadType":"str","repeat":"","crontab":"","once":false,"x":166.5,"y":271,"wires":[["703feba3.f74ba4"]]},{"id":"701d5fcc.86432","type":"inject","z":"cedb2490.c23188","name":"Bright Max","topic":"","payload":"bright_max","payloadType":"str","repeat":"","crontab":"","once":false,"x":158.5,"y":314,"wires":[["703feba3.f74ba4"]]},{"id":"e103214f.25c99","type":"inject","z":"cedb2490.c23188","name":"Night","topic":"","payload":"night","payloadType":"str","repeat":"","crontab":"","once":false,"x":152.5,"y":357,"wires":[["703feba3.f74ba4"]]}]
To control the bulb pass the command in to the msg.payload:
- 'on' - Turns the bulb on (white and color)
- 'off' - Turns the bulb off (white and color)
- 'white' - Sets a color bulb to white (color bulb only)
- 'disco' - Cycles a bulb through all the colors (color bulb only)
- (a number not a string range 0 - 255) - Sets the hue of the bulb (color bulb only)
- (a number not a string range 0 - 100) - Sets the brightness of the bulb (color bulb only)
- 'bright_up' - Increase the brightness of the bulb (white bulb only)
- 'bright_down' - Decrease the brightness of the bulb (white bulb only)
- 'cooler' - Make the bulb cooler (white bulb only)
- 'warmer' - Make the bulb warmer (white bulb only)
- 'bright_max' - Make the bulb brightness maximum (white bulb only)
- 'night' - Turn the night mode (white bulb only)
Important: for setting the brightness and color of the color bulb, msg.command needs to be set as following:
- 'brightness' - Set brightness
- 'color' - Set color
