node-red-contrib-mikrotik 0.7.0
Node based on node-red-contrib-mikrotik to work with Mikrotik devices which fixes device configuration problem
npm install node-red-contrib-mikrotik
CLA assistant compile CodeFactor npm version
node-red-contrib-mikrotik a mikrotik node for Node-RED
NPM
Install via the palette manage in the Node-RED admin ui (no restart needed).
Alternatively run the following command in your Node-RED user directory (typically ~/.node-red):
then restart Node-RED and add an instance of the mikrotik node.
Config
Available actions:
  • log
  • resources
  • wifi
  • connections
  • reboot
  • raw
Add the node to a flow, add an inject and a debug node, configure your connection and you are ready to go.
If you can override every property with the message object. The names are:
msg. -> username, password, host, port, payload/command, ssl
SSL
If you like to have a ssl connection between the node and the mikrotik router see the documentation
Basic
TBD
RAW
For the usage of the RAW/Command mode there are here some examples.
Version: 0.7.0
Updated 2 years, 8 months ago
Rating: 4.7 3
15 in the last week
  • mikrotik
  • mikrotik-device
  • mikrotik
  • Ahmed Al Hafoudh
  • Nikola 0nikola1
  • Konrad Mattheis
