node-red-contrib-mic 0.0.1
Node-RED node for microphone (based on nodejs mic : a simple stream wrapper for arecord (Linux (including Raspbian)) and sox (Mac/Windows)).
Run the following npm command in your Node-RED environment.
npm install node-red-contrib-mic
This package add 1 input node (Mic) to Node-RED.
The Mic node expect the following payload :
start
(or empty): Start recordingstop
: Stop recordingpause
Pause recordingresume
: Resume recording
The Mic node comprises the following options:
- Output payload type: Type of the payload output
Stream
: On start recording, emit one message with a Readable stream as the payloadBuffer
: When recording, emit multiple messages with a Buffer as the payload
- Endian:
little
orbig
, default:little
- Bitwidth:
8
or16
or24
or anything valid supported by arecord or sox, default:16
- Encoding:
signed-integer
orunsinged-integer
, default:signed-integer
- Channels:
1
or2
(mono) - Device:
hw:0,0
orplughw:1,0
or anything valid supported by arecord, default:plughw:1,0
- Rate:
8000
or16000
or44100
or anything valid supported by arecord or sox, default:16000
- Silence timeout: The 'silence' signal is raised after reaching these many consecutive frames, default:
0
- Stop record on silence:
true
orfalse
(useless with Silence timeout set to 0), default:false
- Debug:
true
orfalse
- can be used to help in debugging
##License The MIT License (MIT)
